Deciding between a new 2010 and a used 2005-2009 Prius. Need help!
Discussion in 'Gen 3 Prius Fuel Economy' started by lethalsvt, Dec 30, 2010.
  1. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I would base my decision on money and ergonomics. The Gen II may be uncomfortable for some drivers (particularly taller people like myself) so it may take effort to make things work. I performed some "surgery" and all is well. Many think it's fine from the factory. Others remain dissatisfied after expending considerable effort. Advantage here goes to Gen III, which may not be perfect but does give a driver more adjustments to play with. An extended test drive in each will help.
    You should also spend time deciding which instrumentation & control scheme you prefer. Gen II climate and audio controls are concentrated mainly on the touch-screen MFD. Gen III offers real buttons but moves the fuel economy and energy displays to a smaller, arguably less "pretty" display in the main cluster.
    If in need of a replacement car tomorrow I honestly don't know which way I would go. Take your time getting to know them.
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    The Gen II is incredibly reliable and IMO looks better (modified) than a Gen III, but naturally it's styling is a touch out-of-date compared to the Gen III. It saddens me to finally admit that.
  3. abasile
    abasile Junior Member
    28
    Southern California Mountains, elev. 6130'
    We purchased our 2010 used through the Hertz Rent To Buy program. We paid $17,900 for a vehicle with a bit over 21,000 miles and no significant cosmetic issues. As we figured that most folks renting the Prius are paying a premium to drive a "green" car and are less likely to drive aggressively, we did not have concerns about buying a rental car.
    I would also add that the traction control is improved in the 2010 model, which might make a difference if you drive in snow. IMHO, the 2010 styling is much nicer as well.
    51,486
    have you given due diligence to the question of unintended accelleration?
  5. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Were you able to get it to produce more power? That'd be a great mod and most welcome.
