Decrease in gas mileage on 2010 prius
Discussion in 'Gen 3 Prius Fuel Economy' started by rjp123, Sep 19, 2013.
  1. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    If your 12v battery is still original, I think you'll find, based on history of threads on PC, the 12v battery is the likely culprit.
    52,855
    you've done the battery testing, now you need to find out if those numbers meet spec or fall below. i am not qualified to answer. you can either search for threads with the answer, or wait until someone replies. whatever you do, don't take the dealers word, most are incapable of diagnosing a 12v battery. they will either replace a good one (and your mpg's won't change, $300. down the drain) or they will tell you it's fine, when it was the culprit all along. if you're lucky, they will guess right.:rolleyes:
  3. rjp123
    rjp123 Member
    112
    63
    300 sounds really expensive. Is there something special about the Prius 12v battery compared to a regular car battery?
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Probably includes any "diagnostics" done and labor charges.
    SCH-I535
  5. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    With 107,000 miles on our 2010 Prius we are still getting the same MPG's as when new. Weather
    is the biggest influence on mpg's, more so than any other car I have owned. This is from driving
    since I legally could back in 1966....
  6. bisco
    52,855
    the oem is expensive and the aftermarkets are not much cheaper, although, they do pack more punch and can stand to be drained now and again which the oem does not appreciate. it's a small battery and not liquid, so kind of rare. dealers charge a fortune to replace so you can save a bit doing it yourself. i think the battery is $200. and maybe $150. for an optima yellowtop.
  7. rjp123
    rjp123 Member
    112
    63
    From what I've read so far it seems like my 12v battery voltages are good.
  8. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Another thing to look for is if the foot-operated parking brake is on (even partially) or if any of the brake calipers are stuck, imposing a drag. I would jack up the wheels and see if they rotate freely. The front, I suppose will move a few degrees but should do so freely I would presume (never checked the fronts on mine).
    My MPGs initially were great and climbing into the early 60's and then they came down and settled around 55 in summer and 47 in winter (I have a 3.7 mile commute each way). Then mysteriously in the middle of last winter, they started to climb back up again into the late 50s and the car generally seemed to glide a lot better and easier and the pickup felt stronger. This improvement lasted for a week or so and then came back down. I suspected the calipers sticking and such and paid $50 for the dealer to do a brake inspection but according to them everything is good with the brakes and they aren't sticky. I always use the foot-park-brake whenever I park the car.
    All parameters on my car are normal as yours and so I would be very interested in what you find out with yours.
  9. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    See cwerdna's questionaire on fuel economy troubleshooting. It is a sticky thread. Could be alignment, a brake dragging (how does it glide now compared to before), or any number of things, but it is not normal to lose mpgs just by time or wear. I'm not sure what you mean about top end cleaning. And the treatment to clean throttle body sounds like something was dumped in rather than taking it apart and cleaning it, so I'm not ready to rule that out.
    12V is a common issue, but yours seems ok.
  10. rjp123
    rjp123 Member
    112
    63
    I checked my tires and they were all around 33 psi. I increased them to 40 just as a test and the mpg seems a little better. The door sticker says to run 35 front/ 33 rear, but the tires themselves say 51 psi is max. What pressures are you guys running?
  11. bisco
    52,855
    i run mine at 40 f and 38 r, seems to be the consensus here for decent mileage, handling and ride comfort.
    rjp123 likes this.
  12. bwilson4web
    16,535
    I'm running 51 psi in the Sumitomo T4s which were bought at the Toyota service center. Every two months, I top them off.
    rjp123 likes this.
  13. rjp123
    rjp123 Member
    112
    63
    Why do you suppose Toyota recommends only 35 front / 33 rear?
  14. bisco
    52,855
    lawyers.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Nice soft ride!
  16. Inefficientmkts
    Inefficientmkts New Member
    Phoenix, AZ
    2010 prius. I recently discovered that the passenger rear brake caliper slide pin was stuck. The frozen slide pin caused the inner rear brake pad to remain lightly applied at all times. I've owned the car for 2 years and 20K miles and gotten a consistent 44-47 MPG never knowing about this problem. From what I have read, these calipers can have this problem.
    Only came to my attention once the pad wore out and started to scrape the brake rotor. Now the caliper replaced, car easily getting 55 MPG-65 MPG not trying that hard with low AC on. Could never get these numbers before. Friends wondered why my MPG was so low, now we know! Check all 8 brake pads for uneven wear or binding. I imagine that low MPG can only stem from two forces....forces that accelerate (engine, synergy drive, battery) but also drag forces (brakes, tires/rolling resistence, missing underbody panels, worn bearings, etc).
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    All cars in general goes through caliper pins seizures, its part of the maintenance list not problem list.
    RMB and Raytheeagle like this.
  18. Mendel Leisk
    42,347
    deleted
    Grit likes this.
  19. Ellen Berman
    Ellen Berman Junior Member
    16
    Wilmington, de
    Three Touring
    I put fuel injector in as well as changed air filter .. mine increased . I wonder about gas filter changes!
