Deep Noise - Always
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jhigga15, Dec 7, 2011.
  1. jhigga15
    jhigga15 Junior Member
    49
    Fort. Lauderdale
    Hello everyone,
    I have a weird noise from my 2007 Prius. It seems to be coming from he front left of the car. The car drives well, Tracks, feels stable at all speeds. It's just making a crazy noise at almost all speeds, it starts around 10 mph. It's a very DEEP ggggrrrrrrrrrrr. When the car is shifted in N it continues. I thought it was a WB, but it’s not that noise. HELP PLEASE
    Thanks,
    John
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Could be a wheel bearing CV joint or a tire? Hal
    51,140
    most likely.
  4. richard schumacher
    7,664
    1,043
    United States
    Get thee to a dealer ASAP. A failed joint or bearing can kill you.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Please post how many miles on car. I lost the driver front wb on my 07 at 35K miles. It made a pronounced woop woop noise at between 25 to 45 miles an hour.Very wheel specific.Thought it was the tires at first.
    A low pitched grrr would concern me.Please check fluid level in trans asap and check for any fluid leak where inner shafts exit cvt. You may have a worn out inner cv shaft beating up the trans seal causing a leak which eventually would destroy the trans. Our trans are very very expensive.
  6. cnschult
    cnschult Active Member
    772
    97
    Michigan
    i have 2 prius, you may have the same problem as I once did. I heard what sounded like a choo choo train sound from what I swore was the front left of the car. for $15 a brake shop cleaned out the brake dust from the rear drums and problem solved, every time, well at least for another 40K miles or so.
    its always fun to hear how much 'meat' is left on my front pads and rear shoes and then I tell them its all the original brakes and watch their disbelief and awe.
    lessons learned:
    1. acoustics can do funny things to sound waves
    2. horrible sounds can have cheap simple solutions.
  7. jhigga15
    49
    Fort. Lauderdale
    The car has 152,000+ Miles. The Tires are new and aligned (Bridgestone Ecopia)
    The Dealership looked at the car and had it on the lift, they spun the wheels and said that it was not the WB. The Noise starts around 22mph, I double checked yesterday...
    I tried to record it with my phone, but it came out bad...
    I have not had the brakes cleaned... :-(, I will try that
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Have you tried swapping the tires front to rear? That will eliminate tires if the sound doesn't change.
    Tom
  9. jhigga15
    49
    Fort. Lauderdale
    It got loud when I first put 2 new tires on the back and the backs on the front... I thought it would wear even and sort itself out... 1.5 months went by, so I bought 2 new tires and had it aligned... same noise, it's been another 2 months and I need to sort his out, going to see my friend at the dealership to see whats up today...
  10. Hal W
    Hal W New Member
    872
    53
    Did you put the back tires on the front on the second change? If so you have a rear alignment problem! This can be a problem as the rear suspension is not made for alignment! Hal
  11. jhigga15
    49
    Fort. Lauderdale
    They claim it's my front BB... I will let you all know today once my bank account is drained
  12. bisco
    51,140
    :D what is a BB? bed and breakfast?
  13. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Brake Bearing.
    :D
  14. edthefox5
    10,096
    4,831
    Clearwater, Florida
    What's a brake bearing?
  15. jhigga15
    49
    Fort. Lauderdale
    LOL, sorry guys I typed BB for Ball Bearing, but it meant the front Wheel Bearing!!! Car is fixed and back to new.
  16. bisco
    51,140
    glad to hear it! and you're still solvent?
