Deep resonating rumble in 2004 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Todd Kamens, Apr 26, 2019.
  1. Todd Kamens
    Todd Kamens Junior Member
    Arnold, MD
    I have a low mileage 2004 Prius (120K) that is suddenly emitting a deep rumble when the engine is at the transition between starting and stopping by the hybrid system. The sound is most pronounced when the engine is at its lowest rpms and under load. It is similar to trying to accelerate a manual transmission car when the car is in a gear that is too high. Otherwise, it accelerates quietly and smoothly, brakes well, and battery charging system seems to be functioning normally. Any suggestions?
  2. JC91006
    16,936
    8,647
    Maybe someone has stolen your catalytic converter. Look under your car and see if something has been cut off
  3. caravan2429
    caravan2429 Junior Member
    64
    Sandy, UT
    Rear muffler rusted or broken. Check your chassis first.
  4. Todd Kamens
    Arnold, MD
    I have already replaced the muffler and the upstream pipe that has a heat shield welded to it as that weld had let go. Rest of exhaust looks intact. Problem persists after the exhaust repair.
  5. JC91006
    16,936
    8,647
    The shop is probably not a professional shop, forgot the donut gaskets for the pipes.
  6. Mendel Leisk
    42,355
    Noise commenced before the repair then?
