Deer and cables under the car mystery
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by gafortiby, Sep 6, 2016.
  1. gafortiby
    gafortiby Member
    74
    46
    Colorado
    There are two exposed bolts near the white plastic bracket, as well as the one bolt being used to hold up the zip tie.
    I think I can use something like this to secure the cable to the 3 bolts, after I smooth the edges.
  2. gafortiby
    gafortiby Member
    74
    46
    Colorado
    There are two short bolts sticking out circled in red. (One you cannot see from this picture but it is there). I would also want to put something protective on the blue circle since there seems to be some plastic missing there.
    Thankfully, none of the wires are nicked and the orange wire coating is not even scratched.
  3. Mendel Leisk
    41,471
    Great stuff! I repaired a microwave with a fancy broken door latch with it, otherwise it would have been toast.
    #23 Mendel Leisk, Sep 13, 2016
  4. gafortiby
    gafortiby Member
    74
    46
    Colorado
    I intended to use the grey plastic type, but the packaging says "not for extreme cold temperatures." It does get below zero F (-20C) here in the winter.
    I'm going to use some of this to reinforce some points.
    X-Treme Tape TPE-XZLCLR Silicone Rubber Self Fusing Tape
  5. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
    3 years, 15k miles? Looks good to go to the finish.
  6. gafortiby
    gafortiby Member
    74
    46
    Colorado
    It probably will last, but that zip tie is really thin and it is the only thing preventing the cable from dropping down to the floor.
    A few years ago I used zip ties to replace a CV boot clamp. It held for 3 years and 30k miles but then started leaking. Granted that was 6 inches from the exhaust manifold... :D
  7. Air_Boss
    4,200
    1,184
    New Yawk
    I would NOT use any metal hanging strap material on this application. You'd be better off looking at PVC strapping for low and high temperature performance.
  8. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
  9. gafortiby
    gafortiby Member
    74
    46
    Colorado
    maybe i can use this then. Polypropylene strap (gets brittle below 0F though)
    or a ski strap made using polyurethane, since those do not get brittle until way far below zero.
  10. gafortiby
    gafortiby Member
    74
    46
    Colorado
    Had some plastic "plumbers tape" lying around.
    Bought one of these M6 locknuts
    Enlarged some of the tiny holes in the plastic strap to 1/4" (~5mm). Then, loopped the strap around the white plastic and mounted it onto the car. Not bad!
    I'll have to check it in a few weeks, months to see how it's doing. I can already see that the plastic is slightly stressed, (white at curvature) and I am not sure if this is polypropylene or something else. It might crack at the first sign of frost.
    I didn't even have to raise the car, did it all lying on the side of the car.
    #30 gafortiby, Sep 13, 2016
    xliderider likes this.
