DEFEATING ICE OPERATION
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius1, Aug 18, 2013.
  1. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    This observation could be evaluated if there was some way to measure the amount of gasoline saved by taking the load off the engine vs leaving it in a drive mode until it reaches 130°F and turns itself off. So it'd be interesting to follow up on this observation with some data. Not sure what metric to use, though.
  2. markabele
    5,084
    1,782
    Nebraska
    Well obviously the goal is to not have the ICE run at all. But I believe the consensus was that when the engine runs at lower temps it produces more condensation but it eliminates this by the time it warms up properly (burns it off at higher temps). I am definitely no expert on this, just regurgitating what I've heard others say. But it seems to be fairly logical.
  3. markabele
    5,084
    1,782
    Nebraska
    Again, just regurgitating here, not sure where I read it. I believe the engine does the same warmup cycle regardless whether you are moving or not. It simply uses the traction battery to move you during the warmup.
  4. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    People were reporting clanking noises from the ICE the next time it started when it was shut down before it was completely warmed up. I believe there was even a Toyota TSB referenced. I will try to dig up the threads when I have a little time.
    Andyprius1 likes this.
  5. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Has anybody else actually tried what I suggested to attempt to form some type of favorable or unfavorable consensus on MPG. Forget all these useless discussions. Basically we have little control over whether the ICE runs or not, BUT, remember that you are shutting off the ICE, IF you, touch the brake pedal, stop at a light, stop at a stop sign, put the car in neutral. ( with EV option still available )The driver has very little control over when and if the ICE runs, ( after warm-up ) anything the driver does during warmup has little to no effect. Condesation is minimal in a Prius as the temperatures it reaches are the lowest of any other car in the market. It is difficult to impossible to burn your hand.
  6. Andyprius1
    2,327
    859
    Cool CA
    . Good
  7. Andyprius1
    2,327
    859
    Cool CA
    . The stop/Go system dictates that when you are stopped, the engine is OFF.
  8. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I've never heard a clanking noise when the ICE starts. Usually I can't even tell when it starts until a while later. Then I realize...yep 124 miles since the last time it ran. Or, oops, I accelerated hard to pass that car.
    Mike
  9. Ken Blake
    351
    180
    Portland, Oregon
  10. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Seems a bit anedotal for me. But maybe there is something to it for people who just washed their cars, thus getting lots of moisture near it and/or people in colder climates. But even so...is it doing any damage? Or it is just adding a tad to normal wear and tear?
    Mike
  11. Andyprius1
    2,327
    859
    Cool CA
    Never experienced this myself. Exactly why somebody wants to waste gas to warm up the engine, on a car that is known for great economy, is beyond me. If I lived in a cold climate I would deliberately start out in HV and drive briskly to warm up naturally. Later returning to EV. BUT, unfortunately I do not live in a cold climate anymore. I think the whole thing is a anomaly and he should have gone straight to the dealer.
  12. Ken Blake
    351
    180
    Portland, Oregon
    If you read farther down the thread, multiple owners were reporting engine knocking the next start after prematurely shutting down the ICE.
  13. Andyprius1
    2,327
    859
    Cool CA
    I guess the question is: What does Toyota say about this?
  14. bisco
    52,862
    replacement intake manifold.
  15. markabele
    5,084
    1,782
    Nebraska
    Lets see...
    The warmup cycle costs about 10 cents in gas.
    This is a wild ballpark, but say the worst happened and you had to get a new ICE out of warranty...what would that cost...maybe $5,000?
    So in other words....if you think there is less than a .002% chance that shutting off the ICE prematurely is 100% bad for the car...than by all means, make that bet.
    As for me, I'll just spend the dime.
    Ken Blake likes this.
  16. Andyprius1
    2,327
    859
    Cool CA
    Everything in the world is not devided into categories of good and bad, these are only humankinds perceptions. As for interrupting the warmup cycle, there is no such thing. Whenever the option is Hv, the computers will run the engine. One would have to be very determined to never allow the engine to run. Toyota designed the Car so the engine must run every 125 miles anyway, that is actually a very broad cycle, I doubt anybody goes that far without the engine running. Let us know if you can do that. The purpose of my experiment was not dictated by $/cents but only to maximize consumption bars. I believe what I accomplished was a anomaly anyway.
  17. markabele
    5,084
    1,782
    Nebraska
    I, myself, as well as lots of other people on this forum have gone the 124 miles in between times the ICE must come on. Not bragging, just letting you know since that's what you wanted me to do. :)
  18. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    The warmup cycle stops when the Cat temp reaches certain (i recall 400 F) degree -- normal operating temp. The purpose is to prepare for hard acceleration with ICE.
    I don't think it hurts the ICE if I shut it off before Cat temp is reached. I also don't pull over and reboot the car. If I arrive in my garage and PiP is warming up, I turn it off instead of waiting.
  19. markabele
    5,084
    1,782
    Nebraska
    Are you more than 99.998% sure it does no harm? ;)
  20. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I am not sure. It was my conjecture based on a SAE paper Toyota published on PiP. If it is harmful, I think Toyota would have some measure to prevent it.
