Defective Paint 2016 Prius (Black)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Michael A. Saunders, Mar 30, 2017.
  1. Michael A. Saunders
    Michael A. Saunders Junior Member
    Encinitas, California
    I have a 2016 black Prius and the paint near the driver side mirror is starting to peal and looking similar to fish scales. This car has only been hand washed by me since the day I took delivery. Never been to a car wash or pressure washed. I live in San Diego and the car is almost always garaged when not in use.
    Has anyone else experienced this?
    Mike S.
  2. Tideland Prius
    16,195
    It looks like soap or oil marks (left by water evaporating).
    Initial assessment is not the paint because in the first photo, that marking shows up in both the painted door and the plastic mirror housing - two different painting processes.
    What kind of soap are you using to wash the car?
    Imaginex20 and RCO like this.
  3. JC91006
    16,493
    8,403
    Sprinklers?
  4. robsnyder20
    robsnyder20 Active Member
    374
    301
    SW Florida USA
    My jaw dropped when I first looked at it but at second look, maybe it is sprinklers (rusty ones at that). Have you tried washing it with dawn or something that would take this off? As an FYI, you will need to rewax anything hit by dawn.
  5. Michael A. Saunders
    I have been using Meguiar's Gold Class Car wash since my Prius was brand new. I used the same soap on my 2012 Prius with no issues. I am very careful about rinsing with adequate water before drying. The paint issue is very specific to the left side of the car near the driver mirror on the door and also on the front left fender (just ahead of the side view mirror). The right side of the vehicle is perfect with no paint issues.
    I have not used Dawn on the car. Also, the way the paint defect almost complete stops at the leading edge of the door panel and then restarts forward of the "Hybrid" emblem (on the fender) does not seem consistent with the side of the car getting sprayed by a sprinkler. Also, the two areas of concern appear to be spreading over time. I am very careful to not park near sprinklers.
    #5 Michael A. Saunders, Mar 30, 2017
  6. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Have a local body shop at least look at it ,, what did they say ,,, to me something has splashed on the car
    ,,, vandalized ?? Beech or ??? Thrown at car ,,,
  7. JC91006
    16,493
    8,403
    If it's s new car, just bring it to the dealer to sort out. There's a warranty
    Chodronish and RCO like this.
  8. Tideland Prius
    16,195
    Hmm... something must've been sprayed on it.
    Have you taken it to the dealer? Have them take a look. In addition, have a body shop or someone you know that knows a lot about paint take a closer look.
    RCO likes this.
  9. GotRidofSignUpMessage
    GotRidofSignUpMessage Junior Member
    City, State
    Minerals in the water?
  10. Michael A. Saunders
    I am going to take to the dealership this week to see if it is something they will fix under the warranty.
    By posting on PriusChat I was hoping to determine if other people were having this same issue, which would suggest it was a problem which occurred during the painting process at the factory.
    Chodronish likes this.
  11. bisco
    49,693
    never seen anything like it. how old is the car? when did you first notice it?
  12. priusgto
    priusgto Active Member
    193
    227
    Northern Arizona
    Hopefully whatever splashed on it hasn't etched into the clear very deep and can be polished out. I wish you luck getting the dealer to do anything about that under warranty but chances are unless you bought it very recently they'll do nothing for you.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Looks like nuclear fallout to me :whistle: (Fookishima)
    If it's on the paint rather than under it, it should polish out with color restorer, followed up with wax or polymer coat polish.
    RCO and Imaginex20 like this.
  14. Mendel Leisk
    38,873
    I think Tideland makes a good point. For sure consider all the possibilities, but don't latch onto one cause, or exclude the other possibilities.
    RCO likes this.
  15. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    To me that looks like someone throw sulfuric acid ....someone doesn't like you lot....
  16. vince22
    vince22 Active Member
    205
    249
    califorinia
    I'm not a paint expert but it looks vandalized to me.
    Lightning Racer likes this.
  17. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    It looks like water spots. I guarantee if you take a buffer and some cutting compound it'll look like new again.
    Edit: As to why I think it's water spots? The area affected is right near some gaps that water can collect at and it's common after a car wash and the first drive will force the water from gaps to dry on the car causing water spots.
    RCO likes this.
  18. businessph
    businessph New Member
    mountain view, ca
  19. bisco
    49,693
    what did the dealer say?
  20. orenji
    orenji Senior Member
    5,884
    3,486
    Hard water spots, sprinklers more then likely.
    krmcg likes this.
