Delayed transaxle oil change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2005prius, Aug 30, 2019.
  1. 2005prius
    2005prius Junior Member
    New York
    Three Touring
    Has anyone experienced any problems after changing the transaxle fluid later than recommended?
    I ask because I'm approaching 150K and I don't think it's ever been changed. Yes, that's a me problem. :(
    I was told by one of my mechanics that sometimes transmission clutch disks fail after a delayed oil change because the dirt in the oil is holding everything together and the fresh oil will "clean" the grime that is allowing the friction on the clutch disks.
    The transaxle works perfect, and I'm very light on the pedal. I drive the car for mileage, not to race to the next red light.:cool:
    49,490
    the prius tranny is unlike any other. there are no 'clutch discs' and fewer mechanics who have a clue about them.
    just change it and no worries!(y)
  3. Mendel Leisk
    38,726
    Make sure your mechanic uses Toyota ATF WS fluid, from newly opened bottles, Toyota cautions strongly against using anything else, in the Owner's Manual. 4 quarts should do, and any Toyota dealership parts department should have it, or be able to get it. Up here it's $9.14 (CDN) per liter. Get replacement washers for the drain and fill bolts while you're at the dealership.
    Proper level is achieve by filling with the car level, till it starts coming back out. A funnel with about 3 foot of hose extension (keep OD of hose to 5/8" max) is the simplest way to get the new fluid. Perhaps supply your mechanic with such a funnel, brand-new, to avoid contamination with other fluids.
    There's a little info in the attached, just how to check level, and torque value (just for fill bolt, I would use that value for both fill and drain bolts, in lieu of Toyota spec). Gen 2 Repair Manual does not include a drain-and-fill instruction: hey, it's lifetime... :rolleyes:
    2005prius and dig4dirt like this.
  4. 2005prius
    New York
    Three Touring
    I'm going to do it myself. Thanks for the info on the OD of the fill tube. I was planning on doing the change just as you outlined; great minds
  5. 2005prius
    New York
    Three Touring
    Perfect, thanks for the info.
