Deleting pre-programmed radio stations
Discussion in 'Gen 4 Prius Audio and Electronics' started by ssdesigner, Jul 21, 2016.
  1. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    The dealer put multiple entries of several stations in the pre-programmed list. Is there a way to simply clear them so that they are blank? I know that I can enter in a "new" station, but that is not what I want to do. I want the entry to be blank.
    alanclarkeau likes this.
  2. ssdesigner
    304
    241
    california
    2013 Aqua
    I found the closest thing to a fix, in case anyone else is wondering:
    You don't really want to delete a preset station - all that would do if give you 15 worthless presets all tuned to static on 87.9.
    What you want to do is set the number of presets - so let's say there are only 5 stations in your area that you listen to - what you want to do is set the number of presets to 5 and then set your presets to only those stations.
    Apps > Setup > Audio and reduce the number of presets for the number of stations you routinely listen to.
  3. MichelleStone
    MichelleStone Senior Member
    549
    817
    Mariposa, CA
    Where there's a will there's a way. ;)
    ssdesigner likes this.
