Demisting/defogging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pg350, Dec 27, 2012.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Andy,
    What is an Open Windshield Option?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    With a setting of "65", it will definitely take longer. I crank mine up to "HI" and get the windshield almost totally cleared off in about 5 minutes, despite having sat outside all day in temps below freezing.
    And what's with the shouting of a compliant without an improvement suggestion?
    Show us that some thought has went into it by providing a request. Toyota has been receptive to feedback in the past. Electric heating comes with a price & capacity penalty. What would you like to be implemented?
  3. 3PriusMike
    3,101
    2,421
    Silicon Valley
    If the AC was a heat pump then the defrost could use the hot and cold heat exchangers at the same time. This would allow defrosting without the ICE.
    Mike
  4. john1701a
    12,840
    5,312
    58
    PHV is a plug-in hybrid. It's purpose is to significantly boost MPG, not to be an EV. Sacrificing battery capacity for the sake of not using the engine doesn't actually fulfill that intent.
    Put it this way, how many owners would accept warmth blown on the windshield but no where else? We know a complaint would emerge about not also warming the cabin. Think about the penalty that would cause, how much quicker it would deplete the pack.
  5. Hi John , I thought I had made it incredibly clear several times now. It is simple, most cars have access at the windshield to outside air, the Pip does not! One does not need heat to defrost. It is also clear that there is definitely a temp sensor that determines if the engine runs. After the car is outside for a while in cold weather, the engine runs. Nothing can be done about that. I must assume that Toyota reads our posts and will correct these deficiencies. I don't care where ones lives in the US temps of 32 F do come about everywhere, even Florida.
  6. When the car reaches a certain temp, the engine runs, poor design.
  7. Conditions were not the same as yesterday, your system seems to work for a while, then the temp sensor kicks the engine in.
  8. Mendel Leisk
    42,239
    Assuming this is per a regular Prius:
    Any other car (Hondas) we've had over the year had an option in the regular air flow choices to direct air only to the windshield. Typically, there was:
    Vent
    High/Low (vent+heat)
    Heat
    Heat/Defog (the only regular Mode in the Prius that directs air to the windshield)
    Defog (all air to the windshield) (not available on the Prius)
    With the Prius the closest Mode is one that splits the air flow between the windshield and down by your feet. Yes, there's the hells-a-popping front defog mode, but I can't see living with that for an extended drive, and (I believe) it force-activates the the A/C.
    Anyway, just a request to Toyota: a regular "mode" that's windshield directed air only?
  9. ReWe are speaking of PIP only, the other Gens are different. Also a PIA, my gen 2 was
  10. bisco
    52,752
    andy, when you say you can't get fresh air to the windshield, you mean without it hitting your feet as well, correct?
  11. No, I mean at the windshield. If you attach a telltale composed of a thin piece of toilet paper on the windshield with scotch tape you will find that the only time you have air flow there is when the defrost button is on. Poor design.
  12. bisco
    52,752
    then why does my windshield defog when i hit the windshield/floor mode and fan low?
  13. lensovet
    2,615
    496
    Burlington, NJ
    I'd like to know this as well lol
  14. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    In the mode shown on the display in this picture, you will get airflow towards the windshield and floor. And this mode is attained from cycling through the regular face/floor/windshield button, without the defrost button needing to be lit.
    lensovet likes this.
  15. john1701a
    12,840
    5,312
    58
    I thought we made it clear that you are mixing two seperate behaviors.
    PIP does indeed allow outside air. That's what the "LO" setting provides.
    You apparently want the defrost button to never trigger the engine, just like the regular blower modes. In other words, you would like a windshield-only option instead of the current defrost feature. That would be a take-away, which many will find unacceptable. Adding an additional option would be far more appropriate.
    Now, please be careful not to mix the two up anymore.
  16. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...wonder if portable dehumidifier like this might help...uses 22 watts (plug into inverter?).
    Run overnite to dry out car and keep on.
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
    Will it work below freezing? Might be hard to empty! Pun intended ;)
  18. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Before I needed to stick that in my car I'd forgo getting the plug in and just drive a lift back lol.
  19. El Dobro
    El Dobro A Member
    7,102
    3,282
    Funny, mine does that, too. :D
  20. El Dobro
    El Dobro A Member
    7,102
    3,282
    Or a Leaf. ;)
