Denso: spark plug number change?
Discussion in 'Gen 3 Prius Main Forum' started by yeldogt, Jul 24, 2018.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I see that Toyota moved to a different plug (Originally SC20HR11 ... now SC16HR11). My experience is that Toyota typically uses Denso as OE supplier .. vs NGK.
    I'm sure they are fine .... seem to be hotter.
    Any experience -- I'm going to order a set in case I need ... we have other Prius .. so they will get used if I don't put them in the Gen 3's.
    Looks like the NGK part has not changed
    #1 yeldogt, Jul 24, 2018
  2. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    Toyota increase the heat range/hotter in Prius and Corolla. So, Denso increase the heat range 1 step higher from SC20 to SC16. The SC20HR11 is not made anymore. You found on the market as left over from previous production batch
  3. Mendel Leisk
    42,355
    @yeldogt hasn't posted in over two years.
  4. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Installed Bosch double iridium 9621 spark plugs, (0.044) gap, a few thousand miles back.
    Been running great.
    ASRDogman likes this.
  6. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Those are what I've been using...
    xliderider likes this.
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    Runs around $8 a plug in retail car parts stores. I got a set of 4 with free shipping for $27 and change off eBay.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
  9. xliderider
    8,140
    3,280
    Honolulu, HI
