Depleted the 12v question
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by oldscooterguy, Feb 6, 2018.
  1. oldscooterguy
    oldscooterguy Junior Member
    Ohio
    So yesterday I had a painful outpatient encounter and didn't realize I bumped the hazard lights button when I got home.
    Long story short, wife got home 6 hours later and asked about the hazards, I cussed!
    She tried it and no go so I hobbled out in the snow and disassembled the cargo floor and attached a microprocessor controlled charger.
    Hours later I disco'd it and turned it on. Dash lights lit but no start and had hold the start button to get it to turn off.
    This is our 5th Prii so I'm no rookie but I called local Toyota for battery price. Told them 2012 v five with AT and she said she needed vin number to see which battery but it's "$200 is for the battery and $120 installation. When can I drive it in"
    I asked if they use a condom and lube since batteries plus and AutoZone would install for free if I had it towed either place.
    When I replaced 12v batteries in our second gens no worries but when their 12v died nothing would turn on.
    Any reason for me to be concerned with the car sort of turning on after charging? Is it possible a fuse blew? Thanks in advance.
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    A variation of this OEM 12V battery depletion happened to our 2012 v Five (no ATP) several winters ago. Recharging then Reconditioning the 12V battery with a CTEK 7002 Smart Charger did the trick without issue.
    oldscooterguy likes this.
  3. oldscooterguy
    Ohio
    Thanks, haven't checked this cold morning g yet but using intimate 3.
  4. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Couldn't you have connected the charger to the jump points under the hood? They should have been easier to get at than disassembling the cargo area.
    pilotgrrl and Raytheeagle like this.
  5. oldscooterguy
    Ohio
    Durka! I guess it was a combination of pain meds and being furious with myself!
  6. Prodigyplace
    11,696
    11,318
    Central Virginia
    I used to say I have a good memory, but it;s short. Sometimes I am unsure of the "good memory" part. :eek: :cry:
    Hindsight is 20/20 anyway.
  7. oldscooterguy
    Ohio
    Success! Started right up. Now to drive for a bit
  8. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Sounds like the 12v wasn't done charging, I'd have unhooked the positive cable for the charge, and now, I'd let it trickle charge overnight anyway.
  9. oldscooterguy
    Ohio
    After driving 70 miles on freeway battery at rest shows 12.7 volts
  10. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    It will be fine.
