Desalinating sea water electronically
Discussion in 'Environmental Discussion' started by bwilson4web, Jun 29, 2013.
  1. bwilson4web
    16,512
    Source: Tiny Channels Take Salt From Seawater : Discovery News
    An interesting approach, it begs the question of what happens to the sodium . . . sodium hydroxide?
    If it can scale, an awesome technology.
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Let's hope that there are legs to this idea. However, a lot 22 micron channels would be needed to support millions of gal/day that a desal plant generates. Note that the chlorine returns to an ionized state once it has passed pass the electrode, so the two outputs are more salty water and less salty water.
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    It certainly has potential. Long before it can replace industrial desalination plants, it will have to pass through the design stages of replacing hand-held water purifiers meant for hikers, and reverse osmosis water makers typically used on sailboats.
    Not absolutely everything has to be electronic, but it sounds promising.
