Desperate! Transmission problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kelsey, Nov 6, 2014.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    That's an amazing deal! I hope when my battery fails I can find such a good deal. I would almost be willing to travel to Cincinnati
    Kelsey likes this.
  2. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Did you have to turn in the old one?
  3. Kelsey
    Kelsey New Member
    Cincinnati, Ohio
    Nope. Tested it today and only one cell was bad. I was almost positive this would happen, but I needed a car to get to and from school so I didn't really have a choice in waiting to replace it. :/ At least this way I have a spare battery or can sell the cells from that one and it'll pay for the new one.
    theforceprius likes this.
    52,863
    i like the spare battery idea. maybe invest in a conditioner when you can afford to.
  5. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Glad it worked out for you and not very expensive as it could have been. Salvage yards can be a place of great deals for sure.
    Kelsey likes this.
  6. GregP507
    GregP507 Senior Member
    3,002
    481
    First of all, it's not a transmission problem, because there really isn't one. There's nothing to slip, because there aren't any clutches either. Where the problem lies I suspect, may be in the electric motor windings. Smell your oil; if it smells burned, then there's no good news for you, I'm afraid.
  7. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    LOL! Although true.
    In this same light, I do still suggest at least checking the 12v currently. It sounds like you don't mind some risk of being stranded so replacement isn't necessary. But it is a good idea to know what you have. For me, I know I have a dead 12v. It reads closer to 9.9v now after sitting for a while. Just above the minimum coil activation voltage of the HV relays. But, that's all I need. It is almost 10 years old and still ticking. Last night I turned on the Prius after sitting idle for 2 weeks, the last 3 days in weather down to -25C soaking in the cold. It booted right up. Engine immediately kicked on and it sounded like horror screams coming from the vents because the HVAC fans turned on and it was too cold for them to rotate properly. Ironically I had to use it to go jump a friend's Jeep where the battery froze solid. Prius to the rescue!
  8. GregP507
    3,002
    481
    Possible solution: 9"D" cells in a cardboard tube, to be used to jump the 12V aux battery when it goes dead and renders the Prius dead-in-the-water, with over a kilowatt of electrical power on-board.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Oh, I'm just kidding.- I realize that the reason check the 12 Volt Battery is so often recommended is that it is so often a good idea.
    My vehicle is less than 2 years old. But I plan to be very attentive to the condition of my 12 volt as it ages. Read too many posts about the "problems" that can manifest if the battery becomes too weak.
