Despite the Synthetic Oil requirement, 5000 mile change intervals are still "required"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HTMLSpinnr, Apr 30, 2009.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    You don't need Toyota filter for the Prius?
    What's the benefit of extra capacity?
    Thanks! :)
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Did you look at the instructions for the 2010? Not quite so easy. several parts have to be removed and replaced to access the filter and drain plug.
    But yes, there's great satisfaction and savings in DIY oil changes.
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    yeah, DH was concerned about this pita process and how it will affect diy oil changers. it'll be an irritation in the shop too, and that undercover will make it easy to miss an oil leak if they just crank the thing back on, drop the car down off the lift, start it, and go.
  4. darelldd
    6,059
    389
    Northern CA
    I recall that the chief engineer had trouble finding the oil filter on the cut-away car in Detroit!
  5. Patrick Wong
    18,204
    6,505
    Dealers here are selling Eneos (Nippon Oil) 0W-20 for ~$9 per quart. If you can get 0W-20 full synthetic for $5 per quart that sounds like a great deal.
  6. krouebi
    krouebi 2012 Peugeot 3008 HYbrid4
    55
    Grand Duchy of Luxembourg
    looking at it from Europe, the Toyota/Lexus oil change intervals seem a bad joke (though other manufacturers are equally scary). However, other manufacturers like i.e. Volkswagen are currently at 2yr/30,000km intervals - this is linked to an obligation to use slightly higher-spec (and higer priced) oils, but even so, it's less of a hassle.
  7. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    It's not only the Prius.
    The 2010 Camry ICE with the 2AR 2.5L engine also requires 0W-20 oil. However...as HTMLspinnr noted the manuals state that IF 5W-20 is used then follow that by 0W-20 for the next change.
    IOW....you can alternate the two. At 5K 0W..at 10K 5W..at 15K 0W..etc.
  8. hill
    8,799
    Yea . . . even the Gen II allows for either 5w-30 or 10w-30 turning on how hot / cold your location is. I've never even SEEN Ow-20 ... only 0w-30. Let me guess . . . only made by Toyota and other high end price places?
    :rolleyes:
  9. DeadPhish
    2,010
    353
    OUr store also offers free oil/oil filters for life ( SoVA ). Since we discovered that both the 2010 2.5L Camry and now the 2010 Prius require 0W-20 oil we've added a clause to the Buyer's Order that there may be an extra charge ( above $ZERO ) as a result.
    We understand that Toyota's wording requires using synthetic only on every other oil change. 'If 0W-20 is not available then 5W-20 is acceptable.'
  10. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Hmmm. Oil change intervals - Oil type - scheduled maintanance. Good thread, but I'm confused.
    - Seems as if Euro has extended oil change interval requirements, per previous post. How can this be? Does Toyota have overall worldwide standards and warranty requirements?
    - If this 1.8 engine is similar to other Toyota models, with some modifications, why does the stricter oil type requirement + synthetic differ?
    - Does the engine generally run 'hotter' in the Prius?
    - Perhaps the ICE engine on / off cycling - necessitates more frequent changes?
    - Would the newly-required syn oil be available through auto parts stores and usual retailers?
    - I enjoy some DIY as well. Any further details as to the difficulty of a '10 DIY oil change? underbody panels. location/removal of oil filter. special tools required. lifting the car-does Prius have standard jackstand points. average approximate time to complete?
    - Is 'free oil changes for life' a factor that can be used in Dealer purchase negotiation (perhaps the final - "OK, we have a deal if...")?
    - Are there additional maintenance requirements for the Prius compared to a standard non-hybrid vehicle? ie - how does a Prius compare with a Corolla side by side?
    No doubt PriusChat will be a quick link on my PC Desktop for many years to come.
    Invaluable and friendly resource of information, a decade of experience, and expert advice
  11. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Quite the opposite, it runs on the cold side.
    Nope, there's less strain on the engine. Startup is much better than that in traditional vehicles.
    It already is. Though I haven't seen it in bulk, just quart bottles.
    Patience. I intend to provide a document just like this one for the Iconic model, which gets downloaded quite a bit... lots of DIY owners.
    3 people like this.
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    No difficulty ratings yet, though the instructions were posted and they're certainly not cake like before ;)
    For 2001-2003, the change interval was 7500 miles, and I've had the oil come out a light honey at that rate. The engine had a lower MAX rpm though and didn't reach it until higher speeds.
    For MY 2004+, they changed to the "every car is 5000 miles so we don't get sued for sludging again" interval, regardless of the true needs of the Prius engine. It seems that Toyota is still gun-shy in the US for the 2010. :(
  13. DeanFL
    1,015
    355
    Leads to another question Rick.
    You've previously talked about the Prius maintenance reminder. Is it an alert light on the instr panel? Only for oil changes? Driven by the stated interval in Maint manual supplied with the car? Can the 'reminder' be rest / turned off by the owner - unlike BMWs...
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ok then, BUT if we ask you questions, you could answer them right??
  15. HTMLSpinnr
    5,341
    920
    251
    Not sure that it can be disabled, but the procedure to turn it off after the change is in the Owner's Manual in the do-it-yourself maintenance area. Funny thing is they *don't* explain how to do the oil change itself though, only the type and capacity required.
    Of course!
  16. GatorJZ
    GatorJZ Member
    285
    17
    It's now $15 for TWO days.
  17. ambrothe
    ambrothe Junior Member
    99
    Columbus, OH
    Mobil1 has made 0w-20 oil for years, although it used to be very hard to find. It has been re-released in the last year or so, and you'll find it at most parts stores with the other Mobil1 flavors, notable for its bright green cap. The original Honda Insight and my 2007 Civic hybrid require 0w-20, and I've never had any problems finding it.
  18. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Interesting post by Rick J. on the oil change procedure in the 2010. I note the numbers quoted for torque values of 27 ft-lb for the sump drain plug and 18 ft-lb for the oil filter retainer.
    Do these same values apply for an oil change in the 2004 - 2009 Prius? If not, what are they?
    I could find no references to the applicable torque values in the OM.
  19. HTMLSpinnr
    5,341
    920
    251
    Gen II OM typically doesn't go that far anymore. Repair manual does though.
    Gen II:
    Oil plug - 28 ft/lb (38 Nm)
    Oil filter - 13 ft/lb (17.5 Nm)
  20. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    As I mentioned last year, it would be helpful for newbies if the torque spec for the drain plug was added. It's not in the manual, although it is in the Toyota official procedure online (Toyota's procedure has that and the wrong amount of oil to add...:D refilled with 3.0 quarts last time and am having my best mileage so far.)
    Something I didn't notice until now is that the "put the plug back on" step is before the removing the filter step. Ideally, it might be best to put the plug back on after the filter has been removed and replaced.
