Despite the Synthetic Oil requirement, 5000 mile change intervals are still "required"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HTMLSpinnr, Apr 30, 2009.
  1. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Shawn, I don't put my plug back in until I've drained the filter either, just in case anything is released back into the crankcase/pan once the oil filter seal is broken.
  2. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Exactly. Until all the fluids I want removed are gone, I don't start buttoning things back up.
  3. Cmmendes79
    Cmmendes79 New Member
    New Jersey
    I just got my first oil change ( a little over 5,000 miles) at my local toyota dealership, the reminder sticker; however, says that my next oil change should be at 14,000...
    What's that all about?? I thought I was supposed to change it every 5,000??
    Was it a mistake? Can I really wait that long? I want to keep my new 2009 in good shape!
    What do you think?
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    I would follow the Toyota manual and ignore the dealer's sticker. :)
  5. Dolce
    Dolce Junior Member
    61
    Chicago
    For those of us that are not too handy or have the facility space to change our own oil, what is a reasonable price to get the oil change at a Toyota dealership? Does getting oil changed at other shops void the factory warranty if you stick with the prescribed oil?
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    So far the oil change on the 2010 is the biggest perfect storm of P.I.T.A. that I've heard. Not a deal breaker for me, but certainly not convienent or easy. The problem for me is with the minutia of difference and procedure, oil weight and gasket removal, replacements and torque specifications coupled with removal of the plates on the bottom? I find myself where I know I'm going to be uneasy letting any tech or outside mechanic do the oil change, but I'm not a DIY person. Those underbody plates may add stiffness and stability to the car and also reduce drag but dealing with them seems like a pain. I also don't like the idea that my car could be leaking a fluid and instead of my seeing it visibly on the ground when I pull away, it could all acumulate on the invisible underside of the ground plates.
    I know that the plating added some "improvement" but I've got to question if it's worth it.
  7. HTMLSpinnr
    5,341
    920
    251
    One further thing to note - 0W-20 and 5W-20 oil are additional over the oil change price. I couldn't get the dealer to quote me at the time as he didn't know.
  8. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    sounds like a pain to change the oil.
    they should have increased interval to 7500mi(at least) Nissan I heard is now up to 8500 mi changes for 4 cy cars.
    does anyone know what the EU/JP oil change interval is?
  9. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    I had my '07 oil changed today at the dealer. I asked about the '10 requirements and the Service Manager said the new Prius as well as a few other Toyotas now require synthetic oil. They will charge $68 for the service which includes Mobile 1 synthetic. Considering the cost of the Mobil 1 at $28 @ $7/quart retail, and the difficulity of the change, I think I will let the dealer service mine. BTW: the Mobil 1 they use is in quarts not bulk.
    Lee:cool:
  10. xsmatt81
    522
    Vegas
    bring your own 5 qt jug in. It will cost less. $20.50@ wally world.
    my dealer charges 7.50 a quart for syn, ridiculous
  11. hschuck
    hschuck Member
    385
    bay city, ca
    The local So Cal Walmart price for 5 qt jug of mobil1 0W-20 or 0W-30 is $22.
    Mobil is currently offering a $10 mail in rebate for the purchase of the one jug or 5 1qt bottles if bought before Aug 31. Rebate coupon is available at Promotions
    5 people like this.
  12. chukiechz
    chukiechz New Member
    Orange County, CA
    Around $70 for an oil change every 5K miles? Ouch.
    My 06 E55 AMG costs $170 for an oil change. It includes 9 quarts of Mobil 1 and a MB loaner car. This is done approximately every 13K miles or so depending on what the car "needs".
    I hope thats just a high estimate. I used to like to do my own oil changes, but find it easier to just take it to the dealer.
  13. jelle
    jelle Junior Member
    23
    $70/5k miles, at 50mpg, that's equivalent to adding $0.70 per gallon, or effectively knocking down the economic mpg back down to about 40mpg...
    What?
    An oil change should be <$20.
  14. Dreamer
    Dreamer New Member
    50
    on planet earth
    I'd say Toyota is just being careful with the 5k oil change interval . If you drive any distance daily then longer change interval should be acceptable . But if all your driving is short distance never allowing the engine to get up to normal temp a shorter interval might be wiser .
    After ~30+ years of mechanicing on all sorts of engines I'd say the short change interval is Toyota just covering their a$$ ................
  15. web1b
    web1b Active Member
    817
    52
    $70 is bad and you can't even go to Wal-Mart to have it done for less because it's too difficult to access.
    Wipes out much of the fuel economy savings vs cars like Insight and even the Fusion Hybrid and it will be a hassle to make maintenance trips to the dealer so often.
    My current car only needs once a year oil changes about very 12K miles. Many cars are 7500 to 10K changes especially if they use synthetic.
    Typical express lube prices at a Honda or Ford dealer is about $24.99 to $29.99 or less vs $68.99 for the Prius.
  16. walter592
    walter592 Junior Member
    36
    Since it's a hybrid, your engine should have far less hrs/revolutions of operation than a standard car, 5,000 miles, synthetic and it being a hybrid is just plain wrong, not only for the environment but also for the customer $, shame on you Toyota! Sounds like making a special oil filter to "better the environment" and adding under body cladding with no easy way to access the filter/drain is really just another way to force the Prius's out of the jiffy lubes and into the dealers for service where they can set the price......
  17. web1b
    web1b Active Member
    817
    52
    I would rather go to the dealer than Jiffy Lube, but you you can take other cars to their dealers for oil changes for less than $30 and do it much less often.
  18. HTMLSpinnr
    5,341
    920
    251
    There's historic reasoning behind $5k miles on all vehicles - most likely due to sludge lawsuits in other engines.
    Gen I Prius was 7500 miles, and at 4500 MAX RPM (and lower general RPM), the oil sometimes came out as dark honey vs. black at that interval!
    Another thing to bear in mind is the 5k service is "more" than a simple oil change. 5k includes tire rotation, brake inspection/adjustment if needed, general inspections, etc.
  19. web1b
    web1b Active Member
    817
    52
    Other manufacturers car dealers do the same quick inspection and tire rotation for about 50% the price of the $68.99.
    The car shouldn't need that much adjusting and fiddling-with EVERY 5,000 MILES!
    That is annoyingly often, even if it was cheaper.
  20. HTMLSpinnr
    5,341
    920
    251
    Agreed - sadly, Toyota doesn't differentiate between vehicles that need more or less maintenance. That being said, the extra labor of removing/reinstalling panels each time may warrant this in the dealer's eyes.
