Detailing tip - white vinegar
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mediahound, Oct 4, 2013.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I'm thinking another option is an electric leaf blower, that should be able to blow out all the water from all the nooks and crannies of the car.
  2. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    I have removed mineral water spots from glass or paint by wetting a towel with distilled or Reverse osmosis filtered water. a single pass wipe removes the mineral and drys spot free, even if you do not wipe the surface dry.(Same process as the spot free rinse at the car wash.:)
    I have a small RO system in my home for drinking water(3 gallons per day), but RO water is very cheap in most grocery and "C" stores where you fill your own container. The RO water is also excellent mineral free water for use in batteries and mixing with engine coolant.
  3. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Yes, that would work. Just don't use the leaf blower at 6am, to dry your car, like one of my neighbors did one morning. :rolleyes:
    It's not like he doesn't know it's loud, he was wearing hearing protection earmuffs. :mad:
    SCH-I535 now Free
  4. Jon Hagen
    336
    136
    North Dakota
    Yes, if you use a leaf blower, make sure the leaf blower is an electric model.
    A gas engine leaf blower puts the engine exhaust into the blower air stream, a mixture of corrosive combustion products and slimy 2 cycle oil. :)
  5. xliderider
    8,140
    3,278
    Honolulu, HI
    Lol, he does use an electric leaf blower, but it still makes a high pitched whine, loudly too. Something you definitely don't want to be hearing when you've just been roused from a deep sleep. :rolleyes:
    SCH-I535 now Free
  6. mediahound
    903
    155
    Luckily, the car was area in the complex where I live is in an area that is far from anyones unit. I think I could use an electric leaf blower at 6am an no one would even notice unless they already happen to be outside.
  7. mediahound
    903
    155
    Next time I was the car, I will try dry using this method as well as an electric leaf blower, no towels or water blades at all:
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Just my opinion.
    But I bought and used one of those California Water Blade squeegee products. I tried it once or twice, and while it worked...I got rid of it.
    Seemed to me what I was essentially doing in using it, was using it obviously as a "squeegee" and that is using the pressure of the blade against the surface to remove or force water off the finish. This just made me too nervous. Even though it didn't happen while I was using it, I was constantly worried with each use, or "drying stroke" that I was going to not see a rock or contaminate and end up dragging it along a stretch of my vehicle. It simply was not worth the risk to me.
    Where I live, hard water spots aren't really a big issue. But I think there are better ways to deal with the issue than using "acid" in the form of vinegar or using a squeegee to dry your vehicle. On final rinse I use the "no nozzle" puddle the water off method and water spots are non-existent.
  9. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Washing cars in Florida is fun! Not... The worst place to get spots is on the wide plastic strip between the passenger windows. Learned that lesson on my GenII. Always make sure they don't have spots or the coating wears faster with time...
  10. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    I am always amazed about this water spot issue ...
    May I ask what do you do when it rains ??? let say every day for a week ?? Not all day just when you drive ... then dries ... you wash the car again ?
    In my area most of the morning there is mist on the car too.
  11. mediahound
    903
    155
    I don't believe rain water causes water spots, at least not to the extent that water from the hose tap does.
  12. szgabor
    994
    175
    Oceanside NY
    Wow good to hear :) So after the rain all those things on the car (especially if you happend to drove it) not water spots ... got it :D
    Not sure why, but still can not be bothered with water spotlessnes
    mtbiker53 likes this.
  13. mediahound
    903
    155
    Big difference between rain spots that wash right off and hard water spot deposits, which don't.
  14. Jon Hagen
    336
    136
    North Dakota
    Right, Dew or rain water like distilled or reverse osmosis filtered is mineral free and will not cause water spots unless the car was very dirty.
  15. michinnom
    michinnom Member
    162
    29
    I buy the gallon jugs of distilled vinegar from costco and pour about 4 gallons on my car as a prewash. then i scrub really hard with a metal wire pan scrub to get the deeply embedded dirt out in lieu of the clay bar. After my wash, the car is sooo squeaky clean that nothing slides on the surface. literally, everything now sticks! yay. sooo squeaky clean!
  16. xliderider
    8,140
    3,278
    Honolulu, HI
    Someone's in a bad mood... :(
    SCH-I535
  17. mtbiker53
    mtbiker53 Junior Member
    87
    22
    cape cod
    I'm thinkin,just making fun of the 'analness'.At least they make the next owner happy.
    steve
  18. szgabor
    994
    175
    Oceanside NY
    I am driving my car in NYC and around every day there no way that raindrops are distilled water that is just pure nonsense.... mist maybe but there is ALWAYS dust on the car dust in the air. Yes I know people who bring the car out on Sunday wash it wax it (I have no idea what that means) then parks it back in the garage. Often not driving until next car beautification exercise. But that car is not a 24K daily driver ... :D
  19. Eclipse1701d
    645
    224
    Three Touring
    That's not dust. It's asbestos from the old buildings...
    szgabor likes this.
  20. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    I acquired bad water spots on my front windshield at work when the well driven sprinkler hit my car. The paint was easy to clean as it had a good sealant on it but the windshield was a mess. Tried vinegar and lime away very carefully/ please keep off your paint. Then I greased my windows with rain-x. Boy that stuff is nasty but it works.
    Good motivation to keep your car paint sealed or waxed.
