Diagnostic help- strange whirring noise?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gen2enjoyer, May 11, 2026.
  1. gen2enjoyer
    gen2enjoyer New Member
    Michigan
    Car runs and drives fine but I often find the inverter coolant is low (possible leak?) and after driving for a bit there's a whirring noise that goes away at stoplights. Also occasionally makes sloshing noises after powering it off.
    Any thoughts/input are greatly appreciated, thanks in advance.
  2. Seraphim
    Seraphim New Member
    Michigan
    Welcome to the forum, fellow Michigander!
    The usual noise after power-off is the hot coolant getting pumped into coolant heat storage, which serves to help reduce fuel consumption when starting up the next time around.
    The whirring noise sounds like it might be the brake booster pump and/or accumulator. An old thread cited this as a way to confirm:
    As for the coolant otherwise, are you getting any codes related to the inverter cooling system? Usually, you'd get something like P0A93 if there was a leak or the pump sensor thought something was off.
    52,923
    welcome!
    how many miles and how long have you owned it?
    definitely a leak somewhere
  4. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    The inverter coolant path is not very complicated tracking a leak should be quick . Invert fluid not flowing and that system getting hot could produce strange noises. And for sloshing . After car cools move plastic re. I've radiator cap. When you remove the cap you should see coolant or water standing proud at the top of the neck almost ready to dump on the ground what do you see when you remove your radiator cap at a cool state of the vehicle . If you can look down that black plastic filler neck and see nada that maybe part of sloshing . Systems needs be FULL.
    gen2enjoyer likes this.
  5. gen2enjoyer
    Michigan
    Just a quick update, the inverter coolant seems to be mysteriously disappearing after it's driven. Cooling system was recently flushed & cleaned at the dealer and held coolant just fine prior to the procedure. Whirring mostly disappears so long as I keep coolant in it.
    #5 gen2enjoyer, May 14, 2026
  6. gen2enjoyer
    Michigan
    292k+, bought a little over a month ago
  7. Tombukt2
    13,879
    2,521
    Durham NC
    So look at the picture on Google of inverter coolant loop for the model car you're talking about..
  8. bisco
    52,923
    was the inverter or engine coolant exchanged, or both?
  9. gen2enjoyer
    Michigan
    Further update: Issue seems to have resolved itself. Also got it up on a lift and confirmed no leaks.
    #9 gen2enjoyer, May 25, 2026
