Diagnostic mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by chesleyn, Jun 10, 2012.
  1. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Okay, so figured out how to put my head unit on my base model PiP into diagnostic mode. Question... can we do anything in diagnostic mode? I can't disable the reverse beep from this window... is there anything else worthwhile I can do in this mode? Beside accidentally deleting all my destinations that is.
    52,454
    can you change the door lock setting? seat belt beep?
  3. chesleyn
    596
    158
    Los Angeles
    Me thinks nobody knows. :(
  4. Route66Guy
    Route66Guy New Member
    I
    Please share how you got it into diagnostic mode. :)
  5. bisco
    52,454
    i saw that screen once, looked pretty useless, like a bad restaurant, i never went back.:cool:
    DadofHedgehog likes this.
  6. El Dobro
    El Dobro A Member
    7,093
    3,271
    Ditto.
  7. mrbigh
    3,686
    699
    Long Island, NY
    WAITING.....
  8. chesleyn
    596
    158
    Los Angeles
    Well...uhhmmm....errrrr.. Let me dig that up.
    I've been searching the web and cannot find how I did it.. I remember you turn the vehicle on with your foot off the brake to put it in accessory mode, press some button and flip the lights on and off three times.
    But to be honest with you, there is really nothing on the screens. Useless info.
    iPad ? HD
  9. mrbigh
    3,686
    699
    Long Island, NY
    Errrr. no much help with this info
  10. bisco
    52,454
    i think what i saw was a settings screen.
  11. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    To go into diagnostics mode
    1. Press the setup button
    2. press and hold
    (While holding the button)
    3. Rotate the exterior light switch completely 4-6 time (turn off the headlights and drls and on) cycle that switch 4-7 times I'm sorry if it wasn't clear
  12. El Dobro
    El Dobro A Member
    7,093
    3,271
    Ok, I gave it a shot and this is what I did,
    put the car in ready mode,
    pressed and held the set-up button,
    turned the headlight switch all the way on and off three times,
    the display went into diagnostics mode.
  13. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
