Dice iPod pausing unexpectedly
Discussion in 'Gen 2 Prius Main Forum' started by jonathonp, Dec 5, 2009.
  1. jonathonp
    jonathonp New Member
    New Jersey
    I recently installed the latest Dice iPod converter in my 2004 Prius using the VAIS instructions. Works fine except it all of a sudden pauses or stops playing and then a few seconds later starts up again. It does it randomnly with no prompting and at different intervals. I don't think it's a loose wire because sometimes the title screen says "paused". Any ideas?
  2. ualdriver
    ualdriver Member
    358
    62
    Midwest US
    jonathonp-
    The DICE unit is quirky. I've had it for a year and half now or so and it does lots of weird stuff. I'm not sure there's much you can do about it.
  3. jonathonp
    New Jersey
    Ugh! Okay. It sure does some crazy stuff sometims, but sounds great. Thanks.
  4. mattemsley
    mattemsley New Member
    Melrose, MA
    I am having the same issue. We're you able to resolve it? I have a 2007 Prius with Nav system. Dice Silverline, purchased 1/10/2010, and an iPod Touch 2nd Gen running OS v3. I have the Dice in SAT mode and for the iPod switches i have it in the Smart Mode (Off/On).
  5. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    Like ualdriver said, it's just quirky. Nothing really to fix. It works perfectly for long stretches then does something odd. My biggest complaint is how often it comes up with the iPod in locked out "Accessory connected" mode when I don't have the DICE set for that, or stays DISCONNECTED even when it's not.
    - D
  6. Hopopotamus
    Hopopotamus Junior Member
    45
    Passaic, NJ
    I have same problem. Just use AUX on your dice to get rid of the hick up . I noticed that when the car is cold dice hick up lot more common, don't know if this is just me or anyone else have same problem.
