DICE Prius iPod Integration Unit now works for the 2006!
Discussion in 'Gen 2 Prius Audio and Electronics' started by Danny, Sep 18, 2006.
  1. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(2gaydads @ Oct 9 2006, 02:40 PM) [snapback]330238[/snapback]</div>
    As H2OSkier said, it depends on where you want it to be. My iPod is in the lower glove box (when in use), but some have cut a hole in the compartment under the radio and ran the cable there.
  2. Zarzoo
    Zarzoo New Member
    Orange County, CA
    I am a Beta Tester for the 2006 DICE unit and over all it has been really nice. There are some bugs with my setup (such as messed up Artist * Album / Title of Song information, especially when using Shuffle), which I have sent to DICE, but I have not heard back from them regarding my issues. It was pretty easy to install (if you follow the instructions on how to take apart the dash, etc) and it hides away nicely in the glove box (I keep both the DICE box and IPOD in the lower glove box - This is mostly if I ever need to take out or replace the DICE unit, I won't have to take the dash apart again).
    Besides the few issues I have, it is actually really nice to have my IPOD hooked up to the MFD which also turns it on/off automatically - which the AUX plugin does not do.
    If you have any questions, please let me know.
    Nick
  3. 2gaydads
    2gaydads New Member
    <div class='quotetop'>QUOTE(Zarzoo @ Oct 9 2006, 03:12 PM) [snapback]330263[/snapback]</div>
    great -- thanks to both of you for the replies!
  4. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Danny, do we have any sort of ETA on when the shipping will be happening for the group buy?
  5. H2OSkier
    H2OSkier Member
    276
    16
    Thanks Nick !! I was hoping DICE would get most of the bugs fixed before shipping. I'm waiting to buy, what to do what to do :)
    Ken
  6. garyrodriguez
    garyrodriguez New Member
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 4 2006, 03:23 PM) [snapback]328046[/snapback]</div>
    Are there any detailed instructions on how to remove the lower glove box? I'd like to get an idea of how complicated this is before ordering a unit. Thanks
  7. auart
    auart Junior Member
    74
    OK...I have a 2006 with only package #1...It Does NOT have the aux plug in the console....
    I want something to be able to plug in my sirius radio to and maybe the wife's ipod from time to time... All i needed or wanted was the aux input plug in the console...
    Is this DICE unit all I can get, or all I will need to satisfy my needs?
    Will it do what I am seeking?
    Is there a cheaper way to ADD the AUX Plug withour doing this or is this the best I can hope for?
    Just need a plugin for those two things, and never at the same time of course.
    Thanks
  8. eagle33199
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(gary_hou @ Oct 10 2006, 10:21 PM) [snapback]330991[/snapback]</div>
    Here's how it's done: open the glove box. on the right side, there's a little tube thingy (like the ones that keep screen doors from slamming closed), pull it off the glovebox (straight out towards the door). then squeeze the sides of the glovebox to disengage it from the track, and lower it to the floor. very simple.
    <div class='quotetop'>QUOTE(auart @ Oct 11 2006, 12:19 AM) [snapback]331032[/snapback]</div>
    Well, this is probably the best solution out there, but not the cheapest. you could also get an FM modulator (they make many of those with a standard mini plug to work in any audio device), but that has its drawbacks, such as interference. It is, however, cheeper.
    The Dice will give you two input ports, one dedicated to an iPod, and one as an AUX port, similar to what the higher level '06's have. You could plus the sirius radio into the aux port and have the iPod portion for your wife's iPod. this would give you steering wheel and MFD controls for the iPod, but not for the sirius.
    You may want to look into Vais's SLS (http://www.vaistech.com/sls.html). It claims to provide MFD and steering wheel controls for a sirius radio, and also has an AUX port which you could use for the iPod. I only mention it since it sounds like you would use the sirius more often than the iPod.
  9. motty99
    motty99 New Member
    28
    I really hate to have to do this, but I ordered a DICE from Accessory shop...I made the mistake of not going back to this site when done at Paypal...therefore, when I check on my order, I don't have one!...not a big deal, so I thought...
    I have sent numerous emails to the sales department with no response!...I even sent Danny some messages...I included my email from Paypal, showing the purchase...
    I have registered a complaint with Paypal...buyers beware!
  10. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(gary_hou @ Oct 10 2006, 08:21 PM) [snapback]330991[/snapback]</div>
    At home I believe I have a pdf (with pictures) of an installation of a VAIS unit, which is identical in terms of installation. I don't know how to upload that to this site. It used to be here, but apparently disappeared after the crash.
  11. firstgenwen
    firstgenwen New Member
    I installed the Vais Sirius and the DICE in my '06 (package 1) this weekend - both work great. I got tired of waiting so I called Denison directly and ordered mine. Next up will be a Parrot 3200 and a Nuvi!
  12. GeekEV
    GeekEV Member
    417
    NorCal, USA
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 5 2006, 11:57 AM) [snapback]328557[/snapback]</div>
    Agreed, though I've found the color issues general occur with cheaper media. I've not (yet) seen a player accept a cheap-o disc but NOT a better quality brand name (regardless of color).
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 10 2006, 06:16 AM) [snapback]330534[/snapback]</div>
    I would like to know this too, an ETA sure would be nice. I'm getting antsy here... :p I'm sure you've been busy with all the technical problems, Danny. Is there anyway to confirm that our orders weren't lost in the hubbub? (Mine still shows in my account history...)
  13. chuckieland
    chuckieland New Member
    25
    Bad News man
    finally DICE is ready for 2006
    but i just find out that Prius chat accesories shop don't ship to Canada..............
    when i register for new user, Canada is not a option.
    anyway i can get in on this group buy?
  14. Tideland Prius
    16,552
    PM Danny chuckieland. It shouldn't be a problem since I bought two things from the shop - heatshield and DICE.
  15. GeekEV
    GeekEV Member
    417
    NorCal, USA
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 12 2006, 08:48 AM) [snapback]331723[/snapback]</div>
    Except you can't. His inbox is fully and it fails to PM him. I tried when I was going to ask for an ETA...
  16. GeekEV
    GeekEV Member
    417
    NorCal, USA
    <div class='quotetop'>QUOTE(Mr. Zorg @ Oct 12 2006, 12:32 PM) [snapback]331864[/snapback]</div>
    His inbox is also full, not just fully. I would edit, except we're not supposed to do that right now. :)
  17. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    So just to be sure I'm keeping up...
    The DICE is available for 2006 models but there are some bugs right now so I should probably wait to order. Also I can install the DICE unit and have it to be hidden away in my dash where there won't be anything visible or hanging down. And with the DICE I can change songs on the iPod, view the songs title and artist on my audio screen, switch to CD's and Radio and when I turn off my car the iPod will also shut off right?
    Tamara
  18. Zarzoo
    Zarzoo New Member
    Orange County, CA
    <div class='quotetop'>QUOTE(Tlyke1983 @ Oct 13 2006, 12:53 PM) [snapback]332363[/snapback]</div>
    Yeah, the DICE unit will do all of that. It will control turning on / off the IPOD when you power up your car (my favorite feature). It will display the Artist / Album / Song on the Audio Screen / MFD (this is the buggy part of the DICE currently, but it can be fixed by pressing the 1 - 6 Disk buttons on the Audio Screen then pressing the Map / Audio buttons to refresh the screen; kind of a pain, but I have gotten used to it). It can easily be hidden in either Glove Box (I prefer the lower one) so you will not see anything hanging out. You can also switch the the JBL 6 Disk Changer, Aux Plug, or Radio as well. The DICE / IPOD are treated as a separate input for the Stereo.
    I am loving it. The only thing it doesn't do, which I wish it will eventually, is have the ability to do switch to and from Shuffle from the MFD. Currently you have to put it into Shuffle, Album or Playlist by using the IPOD controls. You can skip songs back and forth using the MFD / Steering wheel however, which is nice.
    Hope that helps,
    Nick
  19. motty99
    motty99 New Member
    28
    <div class='quotetop'>QUOTE(Zarzoo @ Oct 13 2006, 02:49 PM) [snapback]332398[/snapback]</div>
    Has anyone heard anything?...a bit disconcerting not getting any feedback at all, especially from Danny...
  20. teleboydoug
    teleboydoug New Member
    Hi Guys,
    New here... very interested to read about the DICE unit, and ordered one last week. Got it, followed the posts here, got the glovebox and AC dash cover removed, but can't seem to easily access the rear of the radio. Is there a trick here? Thanks for any guidance.
    I saw several references to a VAIS URL, for installation pix and detailed directions, but that link didn't work.
    Doug
