Did EGR Valve Cleaning - Check Engine Light Came On
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jason Franciosa, Dec 18, 2018.
  1. Jason Franciosa
    Jason Franciosa New Member
    28
    I Just cleaned out the EGR Valve following the Nutz and Boltz video. Everything went very smooth and had no issues. Got everything cleaned up and back together. Turned the car on and now the check engine light is on.
    Any ideas what could cause the check engine light to go on from an EGR Valve cleaning?
  2. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Check the MAF sensor if you plug it back..the first time i did it i forget it
    m.wynn, Raytheeagle and Bay Stater like this.
  3. Jason Franciosa
    28
    Yup! I forgot to reconnect it.
    However, I reconnected it, took it for a test ride and it felt fine, but, check engine light is still on.
    Tariq87 likes this.
  4. Jason Franciosa
    28
    Just disconnected the battery, will see if that resets the check engine light. I don't have an OBD-II reader at the moment
    Bay Stater and Tariq87 like this.
  5. Jason Franciosa
    28
    Check engine light cleared! I'll have to drive it a bit to see if it comes back on, but, thank god! I was worried for a bit there.
  6. Mendel Leisk
    42,383
    It can take 4~5 start ups to clear it. That was my experience, with disconnected MAP sensor.
    Bay Stater and NutzAboutBolts like this.
  7. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    How many miles and how dirty was it?
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Actually @Tariq87 with the diagnosis of the issue;).
    I would have guessed anything in the air delivery system as there couldnhave also been a gross leak, like forgetting to connect the PCV hose:rolleyes:.
    But at least it is sorted(y).
    m.wynn likes this.
  10. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    remember when disconnecting the 12v battery , if you have a battery tender , hook it up under the hood , the positive terminal is in the fuse box under the red cover , negative goes to any metal , reason you do this is you won't "lose" and setting you have set up in your car such as your radio stations
