Did I ruin my EBH?
Discussion in 'Gen 2 Prius Main Forum' started by Rxmxsh, Oct 24, 2012.
  1. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    It's been a few years since I've been able to use it. I just moved to an area that it might useful only to find it like this:
    http://i.imgur.com/z9U1R.jpg
    Is it usable or salvageable?
  2. fuzzy1
    10,628
    It looks very easily salvageable to me. Just clean the corrosion off, let it dry well, and make sure there is no residue left on the plug face between the prongs.
    It will probably work just fine as is, but that wouldn't stop me from cleaning it.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    As Fuzzy1 said should be no problem at all just clean the pins.
  4. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    Thank you. Any cleaning tips?
  5. Patrick Wong
    18,210
    6,515
    Use isopropyl alcohol (aka rubbing alcohol) as a cleaning solvent.
  6. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    Thanks. I have some alcohol readily available. I'll try that.
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I'd clean it first with some moistened baking soda and finish it off with a cloth and some light machine oil. Cleaning it with a light oil will help prevent further corrosion.
    BTW Rxmxsh, every time I see your avatar it makes makes me so glad that animated ones are disabled on the new forums!
  8. fuzzy1
    10,628
    If the the alcohol and baking soda aren't enough, then I'd move up to some fine sandpaper, or anything with a mild abrasion.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yep, steel wool is also really good if the milder solution don't work well enough. Still make sure you finish it off with a good rub of oil, or even vaseline, to prevent further corrosion.
  10. Mendel Leisk
    42,080
    Please try to post the pic directly here, it's really easy now. Just click on the Upload a file button at bottom, navigate to your image and select it, and you can choose to show it in the message. When I click on the linked image get nothing, likely due to my work computer having some policy, but...
  11. Mendel Leisk
    42,080
    After clean up try putting an ohm meter across the 2 main prongs: there should be around 30~40 ohms. If it's infinite you have a problem. And if the issue is with the plug they're relatively easy to replace: cut it back a bit and solder a similar plug on. Be sure to stagger the splice locations so they're not all at the same point along the wire, and wrap everything securily.
  12. WE0H
    WE0H Senior Member
    3,247
    528
    All else fails an old tooth brush and some gritty toothpaste will scrub that plug clean :D
    Mike
    Mobile on my SGH-i717
  13. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    ha! It's been a while since I've been on here. Quite the change.
