Did you consider the Honda Clarity before your Prius Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by Skapruisprime, Feb 18, 2018.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Nope, not assuming.
    The Honda Clarity provided Level 1 charger looks a bit familiar...
    Rob43
  2. Tideland Prius
    16,556
    12 hours on 110V for the Clarity
  3. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    That is absolutely correct. (y)
    Honda Owners:
    If any Honda Clarity owner were to build the same 120v to 240v conversion plug I have detailed in this thread:
    Using the Primes 120v Charger at 240 Volts, Cost $59 !!! | PriusChat Posts 1, 2, & 50
    Your 12 hour charge time would get knocked down to roughly ~5.5 hours to a full charge.
    Rob43
    Tideland Prius likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,019
    8,953
    New England
    That was another reason I decided not to purchase Clarity when I was looking for a second car. While the 49 miles EV range is perfect for my 18 miles (one way) daily commute, a long charging time on L1 could be a problem. Installing L2 would mean thousands of dollars of additional cost for my situation, and it was not something I wanted to undertake at the time.
    Blauer Glimmer likes this.
  5. Tideland Prius
    16,556
    That's assuming you use all of its range per day (which means you're in HV mode in the Prime).
    If you're within the Prime's EV range, then the Clarity will only take as long as the Prime. The charging rate is the same for both IIRC - roughly 7km/h (or 4ish mph).
  6. Salamander_King
    11,019
    8,953
    New England
    Yeah, my commute is 37 miles without any side trips. I often run a few errands in town adding a few more miles on my regular commute distance. With PRIME I always run out EV range by the end of a day. With Clarity, I may have a few miles left, but still likely to take 10+ hours to top off. Besides, when I was considering Clarity, I was thinking to add Clarity along with PRIME. I could not be able to charge both cars at the same time on my current electrical panel.
  7. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Ouch.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I took one look at the side profile of the Clarity and moved on:eek:.
    This is much better:
    86D246FA-EFF6-41CB-9C7F-D66101E2F638.jpeg 767E918E-F2AE-4C6E-AD83-243BEEE636CF.jpeg 8C3281F6-BD65-4908-AF5A-4D5FF273BD66.jpeg
    caymandiver75 and m.wynn like this.
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    One does not need to charge it completely. When you need to go unplug then go. You got the gas to take you the rest of the way. (At this point just suggesting a possibility for someone else considering with similar situation to you). 36/49 is 73%. This would roughly be 9 hours of charging. On days you use up more, you also fill up more because filling up the last portion (to full) is slower rate taper, than the bulk filling when battery is low...
  10. Salamander_King
    11,019
    8,953
    New England
    In fact for PHEV, like PRIME and Clarity, one does not need to charge at all. For most of this winter, I did not charge my PRIME. Its range diminished to less than 18 miles and temperature below 14F or use of defroster forced ICE to come on anyway, made it very inefficient EV. On top of it, during this winter gas price got ridiculously low, it was much cheaper to run on gas than charge and use EV. Still, for two PHEV/BEV cars in a household, I thought bumping up the charging capability was prerequisite.
    #290 Salamander_King, Apr 16, 2019
  11. Bill Norton
    Bill Norton Senior Member
    2,152
    734
    MONW, Ks.
    This is an unusual way to operate a PHEV.
    I realize you live where electricity costs are high and currently gas is cheap.
    Did all this change after you purchased a PHEV?
    If not, why did you buy a PHEV in the first place?
    jb in NE likes this.
  12. Salamander_King
    11,019
    8,953
    New England
    To be honest, I did not do detailed economic analyses of EV vs HV before I purchased my PRIME. At the time, I was just interested in seeing the newest plug-in PRIUS and test driving it. But after seeing the offer, I could not turn it down. The price of the PRIME PREMIUM was less than PRIUS TWO after all the incentives and tax credits are considered. Therefore, even if I knew what I know now about the cost of electricity being more than cost of gas, purchasing PHEV PRIME over regular hybrid Prius would have been economically advantageous. That said, the gas price was higher and electricity rate was lower when I first purchased the car almost two years ago, not much, but the EV vs HV was about even or slightly better for EV during summer. The cost reversed this winter when gas price hit the all time low and electricity rate went up at the beginning of the year.
    #292 Salamander_King, Apr 16, 2019
  13. NSXT
    NSXT Active Member
    137
    119
    Toronto, Canada
    2018 Prius Prime
    I still think you have a great deal regardless because PRIME has a better MPG than a regular Prius.
    In my case is due to HOV alone daily to/from work. I do need a bit more of EV range which the Clarity was a perfect fit but after owning the PRIME, I only need to fill up gas every 3 weeks and I am still getting 2.5L/100kms (94MPG) since day 1.
    After finding out so many firmware issues with Clarity, takes 10+ hours to fully charge, heavier dead weight of the battery, PRIME is the better choice overall. If SSB (Solid State Battery) is here today, I bet PRIME is a a full BEV by now.
  14. Salamander_King
    11,019
    8,953
    New England
    Agreed. On EV range alone Clarity is better choice for many, but for overall efficiency, utility and reliability, PRIME is on the top. No question about that. ;)
  15. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    Damn, @ $26 I'd jump the ship in a heartbeat.
  16. Trollbait
    12,538
    Only if the two cars would be charging on the same circuit.
    Otherwise, there shouldn't be an issue charging 2 cars on Level 1 for a majority of American homes. Some older homes may have sub 100 amp service, and then charging 2 EVs, and running a couple vacuums becomes iffy.
  17. Salamander_King
    11,019
    8,953
    New England
    Yap, that is the case for my house. The 120V plugs in my detached garage is on a single 15A circuit on a 100 Amp service panel. I have absolutely no room for adding another breaker in my current main service panel. Adding a sub panel and updating the garage circuit to 40A with 240V receptacle was quoted to be ~$2500 labor and parts. If I have both PRIME and Clarity without upgrading, I would have to charge them staggered, making it 18 hours to charge both cars from empty to full.
  18. Tideland Prius
    16,556
    I think this is one aspect that non-PHEV owners or prospective owners don't fully understand. They see the short range and go "well that won't fit my need" and then proceed to buy a gas-only car (not even a hybrid). What they fail to grasp is that you still get that x km of EV range so that gets taken out of your fuel budget daily. (Twice daily if you can charge at work). Also, you can cut back on emissions and gas usage doing short trips on the weekend for groceries or just in-town driving.
    The beauty of the Prime is that it's a Prius after the EV range is exhausted so it has really good fuel economy. A trip within town in HV mode only with the EV portion depleted netted 3.6L/100km going there and 3.8L/100km on the return trip... pretty damn good if you ask me (this is pure hybrid mode... not blended EV/HV).
  19. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Yeah there is one in the parking lot at work. I was surprised it was not as nice looking from any side in person. It is rather large and looks ungainly, almost boat like.
    Raytheeagle likes this.
  20. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    It's actually a bit better than a Prius, both city and highway.
