Did you survive this first winter mess?
Discussion in 'Gen 3 Prius Main Forum' started by eaglesight333, Dec 8, 2009.
  1. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Here in Montreal we got 23.8 centimeters, nearly two feet.
    I prefer not using the Prius on such days, I prefer my wife's Yaris. I *hate* VSC in deep snow conditions. Makes it impossible to do controlled skids.
    I also don't like having to jump 4 feet tall snowbanks to exit side streets into boulevards. If I don't power-jump it, the car lifts up, the front wheels dangle, not enough traction, and I get stuck.
    Whereas with the Yaris, I can drive up and over it slowly, rotating the wheels right/left at high speed, and get out.
    The Prius VSC prevents one of the wheels from spinning wildly, they both turn slowly.
    SOOOoooooo, I use the Yaris 5 or 6 days out of the year.
    *** My garage mentioned to me getting metal studded winter tires, that most *other* VSC Japanse cars suffer from a sensitive VSC, all have this problem.
    (Other then 4x4 or AWD cars) In fact, he mentionned on how Jap cars don't have a button to deactivate VSC, whereas US designed cars do have a turn-off switch for the VSC.
    Another example with the Yaris, I can do a controlled slide on an iced highway around a stopped car, without crashing, and maintaining most of my speed. Just keep on going.
    With the Prius, I cannot initiate/test such a condition, all I can do is let go of the gas.
    If I turn the wheel left and accelerate, to avoid a stopped vehicle on the right, VSC will kick in, and I keep going straight.
    Like in a snowed up parking lot. Driving straight to a light pole, at 20MPH, and trying to control / skid around the pole.
    With the Yaris, I let go the gas, turn the wheel left, pull the rear-brake lever, gas a bit, release the rear-brake lever, turn the wheel right, gas a bit.
    With the Prius, when I tried it, I ended up bumping into the light pole at 2MPH, LOL. Only my pride was hurt.
    I suggest you all try it, to gain the proper reflexes, before you become part of a 20 car pileup on the highway, because all that people do is Brake Hard and beeline into the stopped car in front of them.
    You need to *not* brake, but steer. Give it gas in the next lane to turn ON the VSC if the car starts to vacillate / see-saw.
    Braking, activating the ABS, should also help gain control. Just do it in *another* lane.
    IOW, practice at Wal Mart at low speed, buy an orange cone, and try *not* to kill the cone. Steer away from it at different speeds, and different distances.
    Trust me, use a cone, instead of a lightpole like I did. Or, a Snow Man. But you'll have to build him often !
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    I think you mean Traction Control, not VSC.
    That was my biggest complaint about my '04 Prius, the hyper-sensitive Trac that I couldn't easily defeat. Getting aggressive studded winter tires helped, but in situations say a snow drift across the road where gunning it will help you get through, the Prius would just grind to a stop
    Oddly enough, my FJ also has Trac without a defeat button. It usually works well enough that I don't have to worry about it, as my FJ is normally rear wheel drive, and a brake is applied to a spinning wheel
    Shift into 4H, and Trac is detuned. Shift into 4L, Trac is disabled. As I run studded snow tires on my FJ, I've never had to use the rear diff lock - at least not yet
    I'm wondering if some of these car makers really do test their cars under severe Canadian winter conditions? The best test would be a small uphill grade, one side dry pavement and the other side glare ice
    My '04 Prius would promptly have failed that test. My FJ would apply the brake to the wheel on glare ice, and make it up the grade. So would any other vehicle that applies a brake to the spinning wheel
  3. markderail
    2,260
    163
    Thanks Jay. I meant Trac.
    Wish I could defeat it, wouldn't mind if it came back on at next on/off of car.
    Too bad the next PHEV Prius (2011?) doesn't have it.
    Having that EV-13 battery pack and plugged into AC power, means a true Remote Heater for the car when it's parked in my driveway. I'd still use the EBH.
  4. alokeprasad
    alokeprasad Member
    162
    Ohio
    Can the traction control be turned off on the Prius? Most vehicles will allow you to turn off TC for such situations.
  5. wjterry
    wjterry New Member
    48
    Winchester, KY
    Wow! I didn't know was such a thing as a "controlled slide". Any "slides" I get into ususally cause such a pucker factor that I have to have the seat surgically removed from my butt! :p
  6. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    FYI 23.8cm equals 9.37 inches, or about 3/4ths of one foot. (if it were 23.8 Inches, then it would be only .2 inches short of two feet).
    I ended up with about 18 cm (or 7 inches) of snow this week, and I am happy that we missed the deep stuff. Though I'm sure it won't be long before we get walloped with another storm.
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Some call that drifting. :)
    This is my all time favorite drifting video!
    7 minutes of drifting
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Not really. It is a safety mechanisim designed to prevent overspin on the electric motors.
  9. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
  10. sdleo726
    sdleo726 New Member
    98
    San Diego
    That storm hit San Diego on Monday with some nasty rain... the Prius was driving like a slug in all the adverse conditions, but that's probably a blessing in disguise.
    Winter is finally here, and the Prius has survived quite will... the heated seats work well when the early morning and late night temps are in the low 40s F - brrrr! And the Solar Roof package works great at regulating interior temps so I only needed to use the AC once this week :)
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Low 40s. :doh: That's August weather for us. I'm hoping to see 10°F today.
    Tom
  12. priushippie
    priushippie New Member
    330
    Pennsyltucky
    No problem, I didn't drive my Prius because I am not going to expose it to salt. Instead I drove my Rav4. The prius will rest in the winter like a ground hog.
  13. markderail
    2,260
    163
    LOL me mixing up my centimeters like that. 1 inch = 2.5 cm
    Two feet of snow in 24hr would have been a catastrophe!
  14. qbee42
    18,058
    3,074
    Northern Michigan
    It's not that bad if you have the right equipment. We get snowfalls like that every once in awhile. With this last storm we have had about two feet in the last three days, but it has been heavy, dense snow. Even so, 50 mph winds have blown it around a bit.
    Tom
  15. jayman
    13,439
    640
    Winnipeg Manitoba
    You need a "winter front" to block the grille, then it will warm up. With my '04 Prius, in city traffic at -25 F and colder, it simply would NOT warm up unless it had the winter front
    With the winter front, even at -40 the motor would stll turn off at red lights. True, it only turned off very briefly, but it would turn off
    My FJ also sports a winter front. There is a day and night difference in heater performance, especially at -20 F and colder
    Especially if you routinely have to deal with frozen diapers in the driveway
  16. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Well we had about 13 Inches of snow yesterday with severe blowing and drifting snow on top of that.
    The car handled quite well, except that last night when I came home from work, (work 4P-12A), I noticed that the car acted like I had a flat tire...
    It seemed to be thumping...I can't see anything wrong with the tires, so does anyone know if somehow the snow that builds up in the 17" wheel area (not the wheel well), if that causes some "imbalance" condition that could cause this??? Or was it maybe from the deep snow initially I drove through until getting into more paved road areas??
    Not sure it was quite unnearving on the way home last night...?????
  17. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
    Mud and ice inside the wheel can cause some severe imbalance issues if it won't come loose. Can you isolate it to one wheel?
  18. qbee42
    18,058
    3,074
    Northern Michigan
    I've had that happen on more than one occasion and on more than one car. Typically it happens when I back into deep snow.
    Tom
  19. wjterry
    wjterry New Member
    48
    Winchester, KY
    It's apparent the drivers in the video are all highly skilled and it looks like fun. I suppose they have sponsors or deep pockets that allow them to frequently purchase rear tires.
  20. sallama
    sallama New Member
    Turkey
