Died while driving down the street
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cmdavis38, May 18, 2018.
  1. cmdavis38
    cmdavis38 Junior Member
    US
    So I'm driving down the street and my prius lost all power as in electrical and would not start...left itself in neutral and pushed to the gas station...tried to start it and all I get is the beep sound no dash lights or message board and just won't even try to start...changed the inverter pump and still nothing...battery is good and I don't see any blown fuses so does someone know what to do?
    52,393
    is the inverter fluid moving? might be the inverter. time to have the trouble codes read. how many miles on her?
  3. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    Check the 12 V battery and charge up if it is low. Or, just charge it up anyway. If it does not hold a charge, replace it.
  4. cmdavis38
    US
    Can't make the fluid move as I can't start the car...took the battery and had it tested and it is good...replaced the pump already
    190500 miles
    can't have codes read as I can't make it to the auto parts store because the car doesn't move
    #4 cmdavis38, May 18, 2018
  5. cmdavis38
    US
  6. JC91006
    16,827
    8,600
    There are some fuses in the engine compartment, look for one marked AM2, it's probably blown. Since you already replaced the inverter pump, just replace that fuse if it's blown
  7. cmdavis38
    US
    JC91006 THANK YOU SOOOO MUCH IVE BEEN DOWN FOR OVER A WEEK AND YOU FAVE THE EXACT REASON THANK YOU THANK YOU
    JC91006 likes this.
