Diesel and Hybrid Newbie
Discussion in 'Newbie Forum' started by Viking Heavy Diesel, Nov 24, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Oak Ridge National Labs did a dissection of a 2004 Prius, sort of like a reverse engineering exercise. They are difficult to make out in this photo
    but maybe you can see the thermister leads in the winding
    The connector at the case, at around the 10 o'clock position, is for the thermistor signals. The heavy leads at the 2 o'clock position are for power
  2. dalton2
    dalton2 New Member
    38
    maine
    did know the electric motor was liquid cooled, same cooling system as engine? or seperate?
  3. jayman
    13,439
    641
    Winnipeg Manitoba
    The engine and electric motor/inverter cooling loops are completely separate
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  5. fuzzy1
    10,705
    Also long as you are staying civil, I will too ---
    I had understood that the inverters and electric motors were not designed for 100% duty cycle at high loads, making the Prius not all that well suited for even plugin electric conversions, let alone towing.
    It will need heavier duty components and a bigger cooling system to be able to tow much and still have the long term reliability that the automotive market expects.
  6. dalton2
    dalton2 New Member
    38
    maine
    that makes sence, didnt think about the duty cycle.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    If designed for it, variable speed motors will absolutely handle 100% duty cycles. Eg, the variable speed drives and "inverter rated" motors used for industrial duty, are almost always run at 100% duty cycles
    The Oshkosh Defense ProPulse in the HEMTT is also designed for severe duty cycles, including the typical military requirement for severe ambient temps (Desert to arctic)
    Obviously, a passenger vehicle isn't designed for such a duty cycle. Though the Prius appears ideally suited for taxi cab service. Here in Winnipeg, Duffy's has a large fleet of Prius zipping around as taxi's. Winnipeg is a harsh environment, with winter lows of -40 F and summer highs of +95 F. Their Prius taxis are holding up very well, certainly better than the crown vic's
    About Us - Duffy's Taxi - 1100 Notre Dame Avenue
    This article is dated 2005
    Taxidriver.ca
    This article is from 2008, the Winnipeg Taxicab Board.
    http://www.gov.mb.ca/mit/taxicab/pdf/news/newsaug08.pdf
    According to page 3, hybrids were introduced in 2005 to the taxi fleet in Winnipeg. They quickly gained acceptance and a very loyal following among the drivers, and by 2008 there were 219 Prius taxi's in Winnipeg
    Hybrid taxi's make up 55% of the Winnipeg taxi fleet. There is no way operators would use them if they didn't hold up
