diesel fuel in Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drlarkin, Apr 23, 2008.
  1. dtroescher
    dtroescher New Member
    Carson City, NV
    With the new multi-grade and diesel gas pumps, it is quite easy to add diesel fuel to a Prius. You just have to be at an unfamiliar station. My wife just did this, ignoring the beautiful green handle on the nozzle, which fit perfectly; it was identical in size to the regular nozzle. The apparent key to resolving this problem is to have the car towed without starting up the engine...kind of tricky, when all you're trying to do is put it into neutral to push it out of the way. I also hear the gas tank may have to be replaced because of how hard it is to totally drain one. Swell.
  2. grand total
    grand total Member
    154
    ON, Canada
    In the UK where diesel cars are much more common this happens about 100,000 times a year. There are now organisations that do little else than recovering from this situation. The secret to a successful low cost (relatively) result is to not start the car and call for help. I think virtually every gas station has a number for a local company offering this service.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    That's odd.
    When I checked last year, at a truck stop, it was impossible to insert a diesel pump nozzle into the fill. The truck stop I checked, has two separate nozzles on the pump bay.
    One nozzle handles 87, 89, 91 octane. The other nozzle handles ULSD
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    I thought the diesel nozzles were larger.
    Tom
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    Yes, they were last year when I checked
  6. patsparks
    10,664
    569
    Adelaide South Australia
    In Oz the diesel pumps have a thumb lock to prevent accidentally lifting the diesel nozzle. You need to push the lock across to lift the nozzle off the pump.
    The plate inside the filler prevents inserting a leaded nozzle (now banned) or diesel.
    To select neutral without starting, from the powered down press power button twice with your foot OFF the brake pedal then select neutral. Another press when your done with your foot off the brake, or 2 presses with your foot on the brake powers down again.
  7. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I don't think the OP, drlarkin, was a troll. I could not detect any insincerity whatsoever in his initial and only post. I was surprised that some of you called him a troll based on so little or no evidence.
    I don't know exactly what the law required in terms of nozzle sizes. It may have permitted the grandfathering of nozzles. I know that in the early Nineties, my friends accidentally filled their new Explorer with leaded gas.
    BTW, I just checked the White Pages for a DR Larkin in Fleetwood, NC, and found this:
    Denis R Larkin
    244 Gap Trl
    Fleetwood, NC 28626-9761
    (336) 877-3335
    Household: Helen K. Larkin
    My bet is that the OP, drlarkin, was the real deal, and that he was unfairly the subject of name calling here.
  8. JSH
    JSH Senior Member
    2,605
    140
    PDX
    There are two different sizes of diesel pumps:
    • Most diesel pumps that I use are auto diesel pumps and have one nozzle for 87/89/91 gasoline and a separate diesel nozzle. I don't recall the diesel nozzles being larger than the gasoline nozzle.
    • Truck pumps that are used by tractor trailers have a much larger nozzle and a higher flow rate.
    My 2003 TDI has a fuel fill large enough to accept the nozzle from either a truck pump or auto pump. There is a button inside the fill that opens a valve to vent the tank and allow faster fueling from the truck nozzle. My friend's 2006 TDI has a smaller fuel fill and he can only use auto diesel pumps.
  9. qbee42
    18,058
    3,081
    Northern Michigan
    The diesel filler opening on our boat will take up to a 1.5 inch nozzle.
    Tom
  10. Bims
    Bims New Member
    Vorginia
    THIS IS NO TROLL, MY FRIEND, YES IT CAN HAPPEN...DON'T ASK ME HOW, BUT YES IT CAN HAPPEN.
    DAUGHTERS PRIUS JUST STOPPED, MY HUSBAND WHILE WAITING FOR THE TOW AND HAVING A CONVERSATION WITH HER FOUND OUT THAT SHE FILLED IT UP, A LITTLE AT A TIME BECAUSE THE "THING" WAS TO BIG FOR IT, BUT SHE FILLED IT UP THE OTHER DAY, HAS BEEN DRIVING IT TILL IT STARTED MAKING NOISES AND JUST DIED... TO TOYOTA WE ARE GOING TO SEE THE PAINFUL RESULT, BUT YES, SHE DID, AND NO SHE IS NOT "SPECIAL" JUST wow!!!
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    The diesel pump nozzle is to big for regular size gas size fill holes you have to hold it up to it to make it work and it’s a very imperfect seal and will leak fuel which should alert you to an issue.
    Very very expensive repair in a Prius.
