Diesel hybrid, better or worse mpg?
Discussion in 'Fred's House of Pancakes' started by Priipriii, Aug 7, 2024.
  1. Trollbait
    12,501
    Though the Elantra hybrid has a complex DCT, yet can match the Prius in fuel economy.
    The fuel economy is mostly from using an engine that is efficient for most of a trip. Then maximizing the time spent at its efficient point. The other side provides power during the short times of the trip where the engine alone isn't enough; passing and climbing. Energy storage lets the engine run at more efficient loads when such loads aren't needed to propel the car, and then the storage allows the engine shut off when using it would be less efficient for stretches of road and stops.
    We've settled on an electrical system for this, but hydraulic is also possible.
    It's the rationalization, but isn't true in the case of vehicles in the same class.
  2. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    What was the other part of the hybrid that they were designed to "be a part of a hybrid vehicle from the very start"?
    Maybe you meant that there are some hybrid designs that were designed from the start to use diesels?
  3. ETC(SS)
    7,131
    I made the post more readable.
    English Lit wasn't covered in my Submarine Qualification card.
    Rudolf Diesel's engine was one of those transformational and disruptive technologies that (some people say....) ultimately got him rubbed out
    - OR NOT. ;)
    Opinions still vary, and the murder/suicide/accident/Operation Mincemeat theories all have lots of holes in them.
    As far as 'boats'
    The first operational Diesel Submarine in the US Navy was the USS F-1 (SS-20), which was commissioned in 1912. Since the hull designation wasn't revised to SS-1, this sorta implies that the first non-human powered submarines were not diesel - which is true, because they were NOT. We had a photo-finish tie with Germany who completed the U-19 class of subs in 1912–13 which had the first diesel engines installed in their boats.
    There was a 'yuuge' burst of 'hybrid' innovation in the 19-teens because of Dubbaya Dubbaya One.
    Diesel Electrics came into their own in the sequel. ;)
    We in the US have moved on from them.
    The USN's LAST diesel boat (for now?) was USS Dolphin (AGSS-555) decommed in 2007.
  4. Priipriii
    Priipriii Member
    226
    65
    If we apply this logic to diesels, wouldnt they all benefit significantly if their transmissions were full electric motors? Considering energy cannot be created or destroyed, most of the energy wasted in heat from gears grinding on each other can otherwise not been wasted and stored for later use. In addition all the regenerative braking that could also save energy and your brake pads. What are the downsides besides $ and extra batteries.
  5. PriusCamper
    PriusCamper Senior Member
    12,677
    5,117
    Pacific Northwest, USA
    Yes... It's clearly a loophole that probably won't last very long if more than one person makes use of it.
    In fact, if log trucks were proposed today for the first time and had to go through a full environmental review they'd never be allowed on the roads. The amount of damage they cause have been grandfathered in and other similar sized vehicles that don't haul logs have far more severe restriction on what they're allowed to haul.
  6. Leadfoot J. McCoalroller
    8,067
    7,548
    Pennsylvania
    2018 Prius c
    Other way around. We'd get a significant boost in efficiency if we eliminated the electrical layer and coupled the Diesel engine directly to the drive wheels.
    The problem is, that's essentially uncontrollable, and you'd only get the efficiency within a certain band of speeds. So if we had a traffic management system where that was okay, you'd be scoring some amazing numbers. On public roads as they are now, that's hopeless.
    Ocean-going ship vessels did something like this for a long time, and some still do. Just a prop on the end of the crankshaft.
    Many now require the flexibility of hybrid Diesel-electric drive for maneuverability and control purposes. Trollbait also mentioned that some also get a trim/balance benefit from spreading the center of gravity.
    Using a gadget like the Toyota power-split device is a great compromise to get most of the efficiency of a directly-coupled drive while providing the means to make it actually controllable in traffic.
    fuzzy1 likes this.
  7. fuzzy1
    10,401
    Don't forget the energy losses in the electric generators, motors, and controllers. Those are very likely greater than the mechanical gear losses.
    A huge benefit of the electric system is the infinitely variable ratio CVT feature. The Toyota electric-CVT achives this variable ratio feature while still typically sending a large portion of the energy through the less-lossy mechanical path.
  8. Leadfoot J. McCoalroller
    8,067
    7,548
    Pennsylvania
    2018 Prius c
    Or the added mass of generators and motors sized to handle the entire power flow... 20 pounds of steel gears can handle a lot more than 40 pounds of copper coils.
    ETC(SS) and fuzzy1 like this.
  9. ETC(SS)
    7,131
    Has Toyota fundamentally changed their power split device over last 3-4 generations?
    I'm a frequent and lavish critic of Toyota's corporate culture, but I have to give it to them with the G5.
    Nearly 200BHP
    19" wheels
    Nearly adequate spring and 1/4 mile acceleration.
    Adequate road handling and cabin quieting.
    Decent crash safety for a small car.
    Fairly good standard safety features for a $30,000 eco-hatch.
    Fairly decent wrapper.
    ALL at >50MPG (and over 45mpg real-world!)
    I don't think you can get much better for $30k and if you're going to add $10k by trying to shoehorn a Diesel engine into the car to get more mpg would add enough coin to the street price to price justify a BEV.
