Diff. Color Coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius2010california, Jan 18, 2016.
  1. Prius2010california
    Prius2010california New Member
    Los Angeles
    I have a Prius 2010 and the original engine coolant is Pink Colored (as sold by toyota). I realized the level was slightly below minimum, so I bought the Green colored Anti/Freeze Coolant to top it off. Within minutes, without turning on the engine, I read that it was a mistake to mix coolants. I sucked out 90% of the green coolant out but some of it is still in there. Should I take it to the mechanic to have them drain out the entire coolant? Or should it be ok since there's only a little bit in there? Any help would be great! Thank you
  2. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    Do that to a German car, which also comes with the pink stuff, if I remember correctly, it will turn into slime.
    iPhone ?
  3. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    " I sucked out 90% of the green coolant out but some of it is still in there. "
    Is the green immiscible with the pink?
  4. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    IProbably ok, IF you thoroughly emptied the reservoir tank before starting the engine, then refill it with the proper coolant. Otherwise, a total drain and refill might be prudent.
  5. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Read the bottle ,if it's compatible with long lasting coolant I wouldn't worry about it
