Diff. in ride between Prius IV and V
Discussion in 'Gen 3 Prius Main Forum' started by Bluebelle, Mar 29, 2010.
  1. Bluebelle
    Bluebelle New Member
    16
    Sacramento, CA
    I have had my 2010 Prius IV since October and love it. I inherited a 2010 Prius V with the Advanced Tech package and less than 600 miles on it, which I'll probably keep and give the Prius IV to my son. My question: It seems the Prius V has a rougher, louder ride than the IV. Is this a known problem or is it my car (or my imagination)? :)
    Thanks ~ I know I shouldn't complain....
  2. LeeB
    LeeB Junior Member
    99
    Henrico, VA
    Not your imagination. Take a look at the amount of rubber on the 17" vs. 15 " tires. More rubber = softer ride and greater noise isolation.
  3. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    HUH???? Your "more rubber" hypothesis... is 180...
    the 17s have a larger tire patch on the road....
    17s have less sidewall flex than the 15s, thus the stiffer ride.
    17s with the larger rubber contact transmit more sound thru the suspension in general, but dependent upon tire construction.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Contact area is not the issue here, it is sidewall flex. Leeb is correct.
    Tom
  5. RoyThePriusGuy
    186
    25
    phoenix
  6. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Less sidewall flex = stiffer ride.
    Stiffer ride = rougher ride in the original poster's (OP's) opinion.
    I just took a IV and a V out for some test drives on friday. I would agree that the V had a stiffer ride and better handling due to the 45 series, 17" tires. I would also say that the ride was rougher, because the tires weren't smoothing out the bumps in the road like the 15" tires will do.
  7. bigdog1234
    bigdog1234 New Member
    144
    23
    US
    Completely disagree. Bluebell mentioned both louder and stiffer ride with the V, than the IV.
    Loudness IS directly correlated to the contact area of the tire. The V has tires with larger contact area.
    Stiffness is inversely related to the height of the sidewall. The V has a shorter sidewall than the IV, and therefore, everything else being equal, should be stiffer.
    This all assumes that the same tread pattern, and softness of the rubber is used on both tires. Just evaluating the difference in sound and stiffness based on tire size differences.
  8. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    In addition to the tires themselves, there is also a steering ratio difference between the V and the other models. This also accounts for some of the overall 'ride' impression, as I think it helps provide a sportier feel overall.
    Once you learn to the LKA and the Radar CC, you'll never want to go back.
  9. bigdog1234
    144
    23
    US
    Gotta have a sun roof. A must!
    Solar is also a pretty cool feature (no pun intended) for those of us who live (and park) in hot/sunny weather most of the year.
  10. New_Yorker
    New_Yorker New Member
    517
    69
    FYI . . . That solar panel on the 2010 Prius 4 model is manufactured by a company called, " Kyocera ". Kyocera has broken the multicrystalline silicon solar cell efficiency world record several times over. In addition they have increased the light sensitive surface area of their solar cells, lowered resistance and reduced energy loss due to reflection, all to improve the efficiency of their solar panels. Kyocera claims they are constantly setting the bar for their industry. www.kyocerasolar.com
    They have a facility in Scottsdale, Arizona.:)
  11. bigdog1234
    144
    23
    US
    Well, all I can say is - I like their product. Got to use the solar roof option on the Prius last Summer, and did a very nice job in keeping the interior of the car close to the outside air temperature...still in the 90's, but far better than the usual 120+ baking that most car interiors get in the Summer. A good 20-30 degrees cooler, which then helps to reduce the thermal load that the AC has to work against when trying to bring the cabin temperature down into the 70's.
    IMO, the solar sunroof is a very nice feature.
  12. SDM44
    SDM44 SeƱor Member
    199
    38
    Los Angeles
    IMO, my V is extremely quiet and soft compared to my E92 M3 or Land Cruiser. But then I haven't driven a II - IV for a long period of time so I can't say how smooth or quiet they are over the V.
  13. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  14. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Just thinkin' out loud. Tire tread seemed to always have the biggest difference for me in noise. On my TCH both sets of Bridgestones were loud but the replacements on the third set with Michelin were much quieter (same size).
    I would think too that contact patch might vary some from tire to tire brand / style based on tire pressures and yes even sidewall. May not be so, but it just seems logical that perhaps a soft tire will roll out and be flatter than perhaps a stiff walled V rated tire, thus possibly having more contact area, especially when rolling or cornering. I don't imagine it's enough to really matter, as I really think tread is the culprit. I still think though some sound deadening materails would help quite a bit.
  15. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    I'll say this about my 4 month old V. At first the ride was rock hard, but the more miles I put on it, the more compliant the ride has gotten. Or I just got used to it. I will say that on non-windy days, the only sound you can hear while you're at freeway speeds are the tires.
  16. bigdog1234
    144
    23
    US
    I wonder if that's age related, or has more to do with the temperature warming up?
  17. austingreen
    austingreen Senior Member
    13,574
    4,113
    Austin, TX, USA
    There is always a little extra rubber on brand new tires. When this wears off handling gets better and gas mileage gets better. Temperature also affects the hardness of the rubber. They really have made advances. On my previous car the tire made a huge difference in noise. Tire Rack seems to have good comparisons.
    I went for an in between wheel/tire upgrade to a 205/50R17 continental extreme contact dws. I don't think it is any nosier than the oem 15s. Contact patch is a little less than that on the V, but its a UHP so much more contact than the oem tires. Suprisingly good handling in the rain, which is why I picked the tire. It does has a little too much flex in the sidewall, but that is easily corrected by pumping them to higher pressure. The OP might try going down to 32 psi if that is more comfortable. I like the stiffer feel on good roads, and I did let pressure out for a camping trip to get more comfort on gravel and mud. I know the tires are new, but I'm sure you can get more comfortable quieter ones when you replace them. I need to sell my oem's, so if you want 15s on the V, I'm sure you can make a proffit on the trade.
  18. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    I traded in a Gen I for the Gen III. IMO the ride didn't improve much in 8 years. Must have something to do with the way the rubber is suspended.
  19. Bluebelle
    16
    Sacramento, CA
    I'm so happy to know it's not my imagination. So I guess my bluebelle handle will need to be changed to blizzardwhitebelle. Love my blue IV, but logic dictates I keep the blizzard white V for myself.
    Thank you all for your input!!
  20. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Forget about which rides better. It's which looks better, lol!
