Difference between actual and reported panel consumption
Discussion in 'Gen 4 Prius Fuel Economy' started by Diego Sausen, Sep 28, 2019.
  1. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I'm not talking about distance to empty, obviously the car doesn't know how you will drive in the future I'm talking about the MPG or l/100 km display in the car and hand calculated on the pump. As I said in Gen3 it was off by 6%-8%, looking at some data from Gen4 I would say the BC is not more 4% off.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Sorry, what is BC?
    The DTE and MPG are related and compiled by the computer from the same data set - I've checked it a few times and have seen between 5% and 9% variances. On a long trip with few stops and relatively steady driving, the variance was smaller - normal short trips had a bigger variance - which is understandable as it's got more data to compile.
    I never bother checking it against reality - just use it as a guide - the real pump price/distance calculation is the valid one.
    Awap likes this.
  3. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    BC - on board computer.
    DTE and MPG display are not related at all. DTE is more accurate if you do the same driving scenario every tank, MPG display in my experience is off by roughly the same percentage every time, no matter the driving style.
  4. alanclarkeau
    7,045
    7,593
    No - DTE and MPG use the same data to compute them.
    I was reading on BMW and Mercedes FORUMS and they're saying the same - though it seemed that Merc was even more inaccurate.
    The bottom line is - they're just a guide. To get it 100% accurate, you'd be paying a lot more for the car.
  5. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    DTE uses past MPG data to predict the future
    MPG is only past data and obviously can be more accurate
  6. Diego Sausen
    Diego Sausen Member
    33
    30
    Porto Alegre - RS - Brasil
    2018 Prius
    Hi guys, follow the post update.
    I fueled the car yesterday and it took 34.44 liters.
    So to run the 832.3 km (according to the partial odometer) I used 47.89 liters.
    Which gives an excellent average of 5.75l / 100km.
    Much closer to the average than the computer reports = 5.3l / 100km.
    Also very close to the margin of 7.5% ~ 8% difference between actual and estimated consumption by the car, as reported by other forum users.
    Thanks to everyone for the answers again.
    My spreadsheet is ready for the next supplies.
    One last piece of information:
    Yesterday before fueling, the range it showed on the dashboard was 94km.
    And as I explained in the first paragraph, there were still 8.56 liters left in the tank.
    I found a good margin of safety, because it is not common for him to make 9,10l / 100km.
  7. bisco
    52,891
    it does not take into account the safety margin
  8. Mendel Leisk
    42,369
    Interesting: Wayne Gerdes (CleanMPG website founder) had a pre-production 4th gen for testing, and he found the dash displayed mpg closely matched his calculations. It would seem they hadn't introduced the exaggeration factor yet.
    Just conflation Alan. The only thing preventing accurate dash displayed mpg is Toyota management.
  9. alanclarkeau
    7,045
    7,593
    And BMW, FORD, SUBARU, MERCEDES, VW, AUDI, JAGUAR - all of them have similar discussions on their forums.
  10. Mendel Leisk
    42,369
    A couple of points:
    1. Our Honda Civic Hybrid was the first vehicle we had with mpg display. It was very consistant, either spot-on, or 0.1 pessimistic, in the liters per 100 km method.
    2. A ScanGauge hooked up to our Prius showed fuel economy that matched calculated. The car knows internally what the number is, but someone at Toyota wants the display to exaggerate.
    fuzzy1 and tucatz like this.
  11. Dave Lane
    Dave Lane New Member
    Nova Scotia, Canada
    2018 Prius
    I am late to this discussion, but with my 2018 Prius over 17000 km, I find that on average the car reports 6.9% better fuel economy than it actually gets from measured fuel as reported by the pump. It ranges from 5.4 to 9.1%.
    Your fuel economy does not seem that good (but maybe you are heavy footed!). My average (actual) is 4.7 l/100km over the whole period (and that includes a cold Canadian winter). See my other post is this forum dated September 3rd.
    Dave
  12. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Here in Ontario, pretty much all the gas is E10 (10% ethanol) and likely the Transport Canada (our EPA) are for just gas, so we shouldn't expect to agree there. Also, our gas pumps are "corrected" to 15C but the metering inside the Prius likely isn't, so that could cause some discrepancy.
    Also, I wonder how much the gas pumps can be off without them getting charged? I wouldn't put it past the gas companies to be pushing the limits as far as they can, especially with respect to their "correction" thermometers.
  13. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    At >30k miles on my 2018 Prius, my calculated (real) overall MPG is 54.73 and the reported MPG is 57.40. Of course, it varies with each fill.
    alanclarkeau likes this.
  14. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Yep, really bummed out about this as it is my only Prius that is a steady 4.2ish MPG off from the display. All of my previous ones were less than 2 MPG and usually spot on.
    My first Honda Civic Hybrid (2003) was that bad but the build quality was excellent. Unfortunately they we down hill after their first one and I am not going back.
    #34 ETP, Oct 18, 2019
  15. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    I'd say that's right on the money. 5% above actual calculation is about right- and at 50K my 2017 is right there with you.
    moto z3 ?
    krmcg likes this.
  16. AnneN
    AnneN Junior Member
    39
    Ireland
    I know this is a very old thread so I hope it's OK to go back to it...
    I'm trying to set this spreadsheet up for myself but continually get an error using the formulas that you have shown. Can you tell me what I am doing wrong here please?!
    Thank you.
  17. alanclarkeau
    7,045
    7,593
    I haven't played with spreadsheets since I retired 12 years ago (that one originates from about 20 yrs ago) - but check that the "0" is a ZERO, not an "ohh" as in letter.
  18. AnneN
    AnneN Junior Member
    39
    Ireland
    Thanks for the reply Alan, much appreciated. I definitely used the Zero but out of sheer frustration even tried the letter O just in case! Neither work. So annoying as this is exactly what I am looking for so I can start tracking - first time owning a Prius and going on a long drive today so really wanted to see how the consumption is.
    I guess it's pen and paper until I figure it out!
