Difference between Halogen and LED light
Discussion in 'Gen 3 Prius Accessories and Modifications' started by hardish, Jun 1, 2016.
  1. hardish
    hardish Junior Member
    2001 Prius
    I have 2010 proud and headlight assembly is broken. Need to buy new one and have a question
    What is difference between HID and Halogen headlight assembly? Would it be possible to by halogen assembly and just use Existing LED bulbs?
  2. pauerbach
    pauerbach Member
    101
    34
    Many members here have retrofitted HID bulbs into the stock halogen headlight assembly. The Prius' stock projector lens headlights lend themselves perfectly to this kind of retrofit without annoying glare for other drivers. Here's a great video explaining how it's done:
    Don't bother with LED retrofit bulbs. They're complete garbage - even the expensive ones. The only way to go LED is to buy the entire Toyota stock LED headlight assembly and ballasts. They're very expensive. HID is a much better option.
    HelloHybrid and Dylan Doxey like this.
  3. hardish
    2001 Prius
    Thank you for sharing the video.
    What I am trying to understand is the physical differences between headlight housing, shell or reflector whatever it is called of HID, HALOGEN and LED. Are the housings identical or have physical differences?
    I have a 2010 Prius and not sure what headlight bulbs are in it. The headlight housing was broken, but the light itself still works. I therefore need to install a new housing.
    #3 hardish, Jun 3, 2016
  4. pauerbach
    pauerbach Member
    101
    34
    I've got a video for everything! I could try to explain it myself, but Cnet can do me one better.
    To repair your headlights, you should get the same type of halogen housing than originally came with your car. You can then simply replace the halogen bulbs with HID bulbs like the first video shows (or just keep the regular halogens). This swap doesn't work well in all vehicles. Not all vehicles with halogen lights have the proper focusing lenses - that big round glass orb you see in front.
    #4 pauerbach, Jun 4, 2016
    Dylan Doxey and HelloHybrid like this.
Loading...
