Difference in EV mileage between Base and Advanced?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Greg_M, Jun 19, 2015.
  1. Trollbait
    12,820
    fat cat napping in the engine bay
    52,823
    bole weavils?
  3. Trollbait
    12,820
    Is he transporting flour?
  4. Trollbait
    12,820
    The Advance is 22 pounds heavier with the OEM tires. This will likely have little effect in hybrid mode, but might in EV with the lower power output. If the current tires are heavier than the factory installed ones, that extra weight will have a bigger impact as unsprung weight.
    So it might well be a fat cat.
    edit: Looked up the tire weights. The Michelin Defender is the same weight(19lbs) as the likely OEM tire, and the Goodyear Eagle LS-2 is pounds lighter than that. So the Advance has tires that have a higher rolling resistance, which is exacerbated by being new, than the other car's, and they are also heavier.
    The Tirerack site doesn't say, but check the tires to see if they are unidirectional(there will be an arrow), and if they are mounted in the right direction. Rolling resistance will be worse if they are not.
    #104 Trollbait, Jun 24, 2015
  5. Greg_M
    Greg_M Member
    151
    35
    NC
    Do you really think what you've described would make a 20% difference? I didn't see an arrow but the tires do have on them which side is the outside which would have the same affect as having an arrow. All 4 are mounted properly.
    Checked for cats, mice and bole weevils but found none!
  6. Trollbait
    12,820
    As mentioned previously, the motor alone has less power than the total hybrid system. Perhaps the tires are providing enough additional resistance to push the motor into a less efficient power range.
    The additional weight from the tires and trim will have bigger impact the more stops there are on the route.
    Does the advance have the Technology package? Toyota Prius Plug-in Interior, Exterior & Safety Features
    I don't see the foglights drawing enough power to have much impact even if left on all the time, same with the better head unit, but the sensors for the Pre-Collision system might. Any extra current draw will add on to the tire and weight difference.
    Don't mean to be a bother if this was asked before, but has the alignment been checked recently? It is possible for it to be off and not be detectable by driving.
    Swapping the wheels between the two cars would be a good test. Check the tires while they are off with a tread depth gauge. That will help find unusual wear that might go unnoticed.
  7. Greg_M
    Greg_M Member
    151
    35
    NC
    I believe that the 2012 advanced came with practically everything. It has all of the items that are offered as options on the 2015 advanced. Car was aligned a month ago and tires were balanced last week. Tire depth was 9/32.
  8. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Greg, you said you have decided already which one to keep.
    If the 2012 still have the original 12V battery I would swap batteries and keep the newer on the 2012 even if it is not improving the EV miles.
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Try rebooting.
  10. bisco
    52,823
    i think you may have hit on something...
  11. Greg_M
    Greg_M Member
    151
    35
    NC
    If you mean removing the negative cable on the 12v battery to reset everything I've done that.
  12. bisco
    52,823
  13. Mendel Leisk
    42,324
    Not sure if this has been mentioned, but: your two plug-ins are different model years. Is it possible Toyota's changed the software, between the years, allowing a bit higher EV percentage?
    roflwaffle likes this.
  14. bisco
    52,823
    anythings possible, but we haven't heard much mention of drastic changes. everyone seems to be in about the same boat, except those with severe short range problems.
  15. Greg_M
    Greg_M Member
    151
    35
    NC
    Now this is interesting!
    tire set A is a mismatched set with about half the tread left
    tire set B are almost new Michelin Defender Green X
    First EV test trying to get maximum EV miles. Both cars fully charged at the same time and then driven the next morning. Windows up and no A/C.
    2013 Base with set A tires got 14.9 miles
    2012 Advanced with set B got 12.5 miles
    Second test today. A little more wind. Both cars charged right before taking them out. Windows halfway down and no A/C.
    2013 Base with set B tires got 14.5 miles but I got stopped at 2 additional lights
    2012 Advanced with set A tires got 14.9 miles
    I've never gotten more than 11 EV miles out of the 2012 except for these two tests. I can consistently get around 13 EV miles out of the 2013. This was before the tire switch today.
    I'm charging the 2012 right now. Later today I'm going to drive it to Home Depot and back on tire set A. I drove there this morning on tire set B and came up about 2 miles short of making it back home in all electric. Let's see if it can make it round trip on the A tires.
    Something is still off. Switching tires made no difference in the 2013 but make a significant difference in the 2012.
    BTW, after switching the tires the low pressure light came on. Is there a way to sync the sensors myself?
    Chazz8 likes this.
  16. bisco
    52,823
    my head is spinning.:p
  17. bisco
    52,823
    at the same time you switched tyres, you charged before driving, instead of the night before.
  18. Greg_M
    Greg_M Member
    151
    35
    NC
    Correct, both were charged at the same time under both tests. The first test was the night before and today's test was right before.
  19. bisco
    52,823
    just wondering if the 2012 could be losing any charge overnight.
  20. Greg_M
    Greg_M Member
    151
    35
    NC
    I don't think so because there have been several times I disconnected the charger right before driving it with no increase in EV miles. I will check it to be 100% sure.
