Difference in mileage and battery charge with different driver
Discussion in 'Gen 3 Prius Fuel Economy' started by Tamyu, Mar 5, 2010.
  1. Tamyu
    Tamyu New Member
    126
    42
    Nagoya, Japan
    Perhaps L/100km isn`t a bad way of measuring... It just seems very strange to me that Japan would be km/L while other places using the same measurements would do it differently. It seems it would be easier to use the display as is... A bit of a mystery.
    As there isn`t a lot of long open road where I commute, it is usually 50-40 (45 limit). But a nice glide from 50 to 40 is rare, I think. Usually it`s accelerate to 45~50 then see a light change, or a car decide to turn, or someone comes into my lane and suddenly needs to turn, etc, in front of me then have to brake partway through. I felt really lucky when I managed to just glide to a light without needing to brake until the last bit. There was maybe one stretch where I was able to keep up 50-40 without having to stop. I don`t feel comfortable slowing to where people behind me are inconvenienced, so a big glide dropping 20km is kind of unthinkable for me.
    At first it felt like this was giving me terrible mpg, but it did keep a good amount of battery charge. I would push until I felt the motor come on, and stay there until I hit a good speed, then glide. But once I had picked up speed, I was only using the battery to retain it. Like, 0 to 50 was ICE, then 40 to 50 was battery. Should I be using the ICE even then? It seems a waste to fire it up for just a few seconds...
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Tamyu,
    It is very easy to get caught up in the Prius mechanics, but I find that focusing on anticipatory driving to minimize brake use returns the best fuel economy results. The car is pretty darned good at looking after itself. This means a couple of things:
    • Keep a comfortable distance between you and the car in front of you. More is better.
    • Try to see two lights ahead
    • Try to use foot off the fuel pedal as your only brake. This is not always possible, it is just a goal. It requires planning ahead, and having more time to slow down.
    Mechanics:
    • Glide below 70 kph
    • If you are using the ICE, press the pedal 1/4 to 1/3 down for good efficiency.
    Bottom line: Pay much more attention to the road than to the car. My city is a good place to play the fuel economy game. Other drivers are not aggressive, many areas have timed lights, and traffic is rarely stop and go. I consistently achieve round trips of 30 Km/l in nice weather, and once (once!) hit 35 Km/l. For me at least, anything over 30 km/l is just luck with the signals.
  3. Tideland Prius
    16,668
    Ahhhhhh I see the root of your problem now. So it's the 40-50 bit that's draining the battery! I do applaud you for being aware of your surroudings. You are correct in that it's not convenient (and just rude) to hold up traffic to so that we can pulse & glide (we're already a big target, we don't need to fuel the fire further).
    The only reason I can do 40km/h is that the traffic in my hometown is generally courteous and the blocks are long enough such that the position of the traffic lights allow me to do the 60-40. Also, if the person behind me cruises at 50km/h, then I can pulse to 60 and by the time I slow to 40km/h, he would've closed in behind me and I can pulse and pull away again. Of course I'll pulse earlier if I feel that he's closing in quicker).
    So I propose two solutions
    1. Cruise at 45km/h (the car might EV at that point though, even in cruise)
    2a. Turn on the ICE for the 40-50 pulse
    2b. Try a 55-40 pulse?
  4. Tamyu
    Tamyu New Member
    126
    42
    Nagoya, Japan
    Actually, the first time with trying to make sure I made use of the ICE for the acceleration in the beginning instead of trying to go slow seemed to take care of the battery problem. :D I wasn`t actually trying to avoid using the ICE, but it seems just my normal driving habits were leaning toward using the battery quite a lot. Making sure that I accelerated out of a stop using the ICE until I had reached a target speed kept my battery much higher - yesterday`s commute left me with nearly a full battery upon stopping. Before I was accelerating in the very beginning with ICE, but once started rolling would add speed with the battery instead of going all the way up with the ICE. Thank you for helping me notice this. :)
    Acceleration from 40 to 50 or so didn`t seem to do too much to the battery charge. At the very least, it didn`t leave me with just 2 bars for the entire trip. I am dreading today`s drive though because the temperature has dropped a lot so it will be my first time driving with heat on. It has been between 10 and 15 for most of my commuting so far, but this evening it is supposed to be 3 or 4 with wind and rain.
    In Japan, I don`t think the Prius is a target at all. Gasoline is extremely expensive to begin with - currently about 128yen/l, which is something like $1.46 in CAD (you are in Canada, correct? I don`t know the prices there, but I understand Japan is much much higher than the US) - so cars here usually strive for high mileage. Prius is just a car that is very good at that.
    Together with your comment about me being aware of my surroundings (I think it is just about the same level as everyone else) made me realize that there is a difference in how people are driving here and there. :) Usually here, a car paces itself with the car in front and watches it well while driving. If the car in front slows, then the car behind will begin to slow almost immediately. So when I drop from 50 to 40, the car behind me doesn`t get closer - it drops it`s speed in pace with mine, then raises it again when I accelerate. One time of this is okay, but if it is repeated many times I think that they might notice. It is obvious if I drop speed because while everyone else is keeping pace with the car in front of them, I am not. And if I accelerate quickly above everyone`s pace, I would quickly close in on the car in front - with the car behind me also in pace with me... And the one behind them in pace, etc. So it`s a lot harder for me to glide if there is traffic... So I try to do very small glides of maybe 5 km decrease, trying to keep close to the pace of everyone else.
    2b is difficult because of everyone pacing - I would probably come too close to a car in front if I were to jump ahead of the flow. I think it would work without much traffic, but then it is easier to do everything. :)
    I will try comparing 1 and 2a today on my commute to see a difference. The road and incline is fairly flat both so there shouldn`t be a big difference in conditions on the way and back.
    Thank you again for dedicating so much time to my thread. :)
  5. Tideland Prius
    16,668
    Use ECO mode for the cold drive. I've noticed that it will cut back on heat and will shut off the engine earlier (I think also at a lower engine coolant temperature but I can't remember exactly. It's best to double check with Ken. I'm sure he's posted some graphs or tables somewhere). I was very surprised that the engine turned off when I came to a stop at a traffic light at -10°C so I'm sure 3-4°C would work. Then again, I also have my lower grille blocked :).
    Depending on which part of Canada you're in, it could be as low as 85.9¢/litre to $1.259/litre. Also, not all parts of Canada are suitable for hybrids. There are areas where people really do need a truck (the size of the truck and the engine size of course is debatable but they need something with high ground clearance and tough). Other areas, well, people are simpler and prefer a simple compact vehicle that their neighbourhood mechanic can service and one that's reliable. The candidates are usually the Civic, Corolla, Elantra and Axela (called the Mazda3 here).
    Your comment on the traffic flow and pattern is interesting indeed. I'm generalizing, of course, but people don't speed up and keep the distance if you speed up. If you speed up, then there'll be a gap between you and the car behiind you. That's how I can use the space to P&G. Granted, part of it could be because we have more space given the amount of traffic so cars don't have to be bunched up all the time. Also, most roads are 2-3 lanes each way with plenty of space for street parking without having to resort to parking one side of the car up on a kerb.
    Depending on the speed and the temperature of the HSD and engine, I'm thinking 2a might be better than 1 because the cruise control will drive on the battery if it can maintain it. I've seen it done up to 60km/h in the Gen 2 Prius.
    You're welcome. Thank you for being so patient as we try to find the root of the problem and figure out a solution.
  6. vday
    vday Member
    312
    Israel
    I want to clarify something and apologize for my stupid question.
    Am I to understand that using the CC is not advisable because it keeps a steady speed rather then P & G?
    BTW Called Mazda 3 here as well - for some reason it is the # 1 selling car with Corolla #2.
    I am one of those with the worst KPL (15-17) but am still happy because my previous car got 10 ish and other cars on the road often get 8-9.
    I still have not taken any long trips so hoping for better results.
  7. Tideland Prius
    16,668
    Well depends on the scenario. If I'm on the highway, I'm using CC. If I'm on a main or secondary road, traffic permitting, I'll do P&G. The reason is that P&G can take advantage of the terrain while CC can't (it'll just accelerate uphill and engine brake downhill when you really want to let the car slow down uphill and let the car roll down on the descent).
    Here, the Civic is #1. The Corolla and Mazda3 swap #2 and #3, on avg every month but overall (yearly), the Corolla comes out as 2nd place.
  8. Tamyu
    Tamyu New Member
    126
    42
    Nagoya, Japan
    I will probably try the grille blocking next winter, but now it is just a short time until spring so seems that I would be taking it out before I know it. :)
    As far as heat goes, I am quite comfortable just being inside the car without heat on, but if I don`t turn something on it fogs up the windows. It is much worse when it is colder outside, so I usually keep it set to 18C for heat.
    It sounds like in high places you are paying nearly as much as we are. I thought maybe it would be all very much cheaper there like in the US because of Canada being so close. I haven`t seen prices below about 95yen/l for more than 10 years. When gas prices were very high in the summer, it was about 190yen/l here, so quite painful.
    I think the Prius really does seem to be more of a city-area car. I wouldn`t want to live in the mountains and own one, and most certainly not go down dirt roads.
    I had never noticed that it was spelled Axela. I always thought it was Accela because it is said the same way as "accel" in acceleration. :D
    In Japan the standard cars for just transportation tend to be light cars, like from Suzuki and Daihatsu. The standard car for people living in the countryside or mountains tends to be the Kei Truck - like this; ??? ???? It seems like everyone out in the country has one... Probably similar to pickup trucks in other countries.
    Here it is generally 2 lanes, one going each way, with no space at the sides. Or 1.5(?) lanes, where you pull to the side a bit and stop to let another car pass you. Because everyone is going slowly, there is less room between cars so less room to speed up and move forward. And if there is a lot of room in front and I move forward quickly, the car behind also follows and closes the gap left behind.
    Here is an example of roads - a two lane road I always drive in my commute, and a one lane I also drive regularly (It isn`t one way - you pull over to let other people pass you)
    I just now realized you were talking about cruise control and not just holding a steady speed...:redface:
    I don`t have CC and probably would never use it even if I did. There is never long enough of a stretch to use it - especially on my commute.
    Thank you. I think that we have figured out the low battery, and I think that it has been resolved now. I have come to understand that I was pretty much driving in a way as to not use the ICE, so there was rarely any charging done besides braking regen. Now that I am trying to accelerate from a stop by using the ICE, the battery is staying at a fair amount. (2 bars from the top or about)
    I didn`t get to try out staying at a steady speed compared to using the ICE for minor acceleration... I left late so had to take the expressway in order to make it in time. It did give me a chance to test out pulse and glide at higher speeds (around 100) with a far distance between cars - which went very well. :D Part of the expressway drive has a large decline, so I was able to go very far by gliding there with almost no decrease in speed.
    Too bad it is a toll road...
    Even if my concern about low battery charge has been solved, I am still enjoying discussing the differences between roads and driving styles in other countries. I`ve never driven outside of Japan, so only know a small amount from being a passenger or hearing other people discuss it.
  9. Tideland Prius
    16,668
    Well then I do encourage you to pick up a scangauge so that you can monitor engine coolant temperature and then read up on the thread about grille blocking here:
    http://priuschat.com/forums/gen-iii...62556-2010-prius-grill-blocking-strategy.html
    US is a lot cheaper. Some people do cross the border to refuel but then those petrol stations got smart and raised the price at those stations near the border. It's still cheaper than in Canada but not as cheap as it should be. There's a lot of cross-border shopping and they're far enough south that their prices are more representative of the area. The last time I checked with my friend in Seattle, it's about the equivalent of Cdn75¢/litre using the current exchange rate.
    We are importing kei cars into Canada. Cars that are > 15 years old do not require DRLs and other modifications. They do still need to pass an inspection (and part of that includes stuff like French labels and adding side reflectors on the front and rear of the car).
    The west coast is a particular hot spot (probably because it's the closest to Japan). We have R32 Skylines (GT-Rs, GT-S, M-Spec etc) as well as kei cars like the Sera, Beat, Alto and kei trucks like the Carry and Acti. Here's the site to the dealership that imports these cars
    Japanoid.com - Home
    Just to give you an idea of the size difference between your trucks and our trucks
    I don't know how steep your mountains are but I drove across the Rocky Mountains in both my smart fortwo and the Prius. They both performed well (other than the smart stuck at 90km/h while the Prius can do the 110km/h speed limit with ease)
    The images link to a map. Are you trying to show me a google street view??
    Good point
    Well 2 bars from the top (so 6 bars) is about where it wants to be. Don't worry if you never see it "full". The car keeps the battery at 60% SOC.
    Your expressway is narrow. That looks like a standard width lane! Our lanes on the expressways are much wider to accomodate the higher speeds. What's the limit on that road you showed me? 80km/h?
  10. Tamyu
    Tamyu New Member
    126
    42
    Nagoya, Japan
    Thank you for the link. :) Once I am a bit better at knowing what is going on I may order a Scangauge to get more detail. Now just parsing the displays available is a bit of work.
    I was quite shocked when there was news of people being so upset about gas prices in the US back when it spiked a lot. Then it was still cheaper than the average prices here before the spike.
    Is the difference in price between Canada and the US because of taxes? Or is it less infrastructure to bring gasoline in?
    Are they allowed on the road there? I believe that they are not allowed on roads in the US. When attending university in the US, there were a couple used inside the university grounds for gardening and maintenance - but I seem to remember being told that they were not allowed on any legal roads but only on the private university service roads.
    Allow me to express my shock at the prices on the imports... Those are incredibly expensive. Anything more than about 10 years old here is worthless. It is almost impossible to sell - you must pay to have it disposed of. I always wondered what happened to the older cars that were "disposed of" - now it looks like I know. :D
    For the early 90s kei trucks they have listed... You would not be able to sell them for even about $100 here. You can buy brand new for $6000. :D Even with import costs they must be making a lot on them...
    I remember seeing a similar image and being told that the kei on the back was a backup. :) Unless you run a business I find it hard to imagine needing the kind of space that a regular truck there has. Maybe once every long while for carrying something large, but certainly not everyday?
    Here it largely depends on the road. The expressway relies on tunnels to keep the road somewhat level, but there are some very steep regular roads. However, the speed limits on them are always low so I don`t think it would be a problem going over them. When I said I wouldn`t want to live in the mountains, I meant more that there are a lot of very narrow roads and unkempt roads - sometimes gravel or dirt. Going over something is one thing but living there would make me want something more adapted to that environment.
    Hmm... I am and for me it does go to the street view. I wonder why it isn`t working. I apologize. If you are interested, you can try zooming in to street view I suppose. At least it should be centered to the roads I am talking about.
    The listed limit changes based on weather, but I believe standard is 80. But for the expressway, this tends to be a recommendation instead of enforced limit. If you are driving safely and not going too much faster than the average you will not be pulled over. Usually people drive 80 in the left lane and 100~110 in the right lane.
    Unfortunately it seems you couldn`t see the regular road to compare, but those are much wider lanes. :) They are about 25% wider (I think) than regular lanes. The one lane road I tried to link to is about the width of one expressway lane and it is both ways, not one.
  11. vday
    vday Member
    312
    Israel
  12. Tideland Prius
    16,668
    Probably taxes. There's a federal excise tax and a provincial gasoline tax. And on top of those two taxes, you get charged GST (tax on a taxes lol).
    In Canada, yes. Not in the US as far as I know.
    Yup. They wanted Cdn$10,000 for a Sera :eek:. Granted, all of the cars they have there are low mileage. There was an R32 for Cdn$25,000 that only had 50,000km on it!
    Well farms here are huge so that's one reason. Another is that people tend to do their own renovations so they buy stuff from a store called Home Depot which sells "raw" materials (so wooden planks and boards of al sizes) as well as all the essentials such as piping, fixtures, doors, sinks, cabinets, and all sorts of nails, screws, buttons, knobs. It's basically a one-stop-shop. I have a few co-workers that built their own gazette or shed.
    Ahh ok. We're cheap. We just build over the mountain, rather than tunnel so we have plenty of steep (but paved, wide and well-maintained) mountain roads.
    I couldn't find a way to zoom in. I could in the link that you sent for the expressway but not the small street.
    Ahh ok. Well maybe it's because your cars are narrower? Our posted speed is a limit. There is some leeway (officer's discetion). Our expressways aren't as wide as the U.S. (although some in Toronto are). Out here in the west, they're usually 2 lanes each way but they're separated by a grass median that's at least two lanes wide.
  13. Tamyu
    Tamyu New Member
    126
    42
    Nagoya, Japan
    I think that about half the price of gas here is tax. When gas prices were very high, and were going over 200yen/liter, there was a temporary move to make gas free of taxes to reduce the price. It dropped then to 110 or about that. (Regular price and normal sales tax)
    Of course, once prices dropped just a little bit all taxes were brought back.
    To me the mileage isn`t something rare. Japan is small and commuting is usually done by public transportation. So cars are often only used for leisure. Cars driven only on weekends are common.
    Even with using our previous car for my commuting, and then for leisure - it was 71000km after 7 years. It would have been much lower, but one year we had to drive daily to a far hospital for 6 months straight - which tripled the use for that year.
    Farms would count to me as using for work / running a business. :)
    There are plenty of home centers here selling raw materials, and many people enjoy building their own things... But if there is no other reason (like use for work / farm) to own a large vehicle other than that convenience people do not. The DIY places here will deliver everything to you or you can borrow one of their large trucks to carry the things to your house.
    There are a lot of good reasons to own a big truck I think, but at the same time it seems like I always hear almost everyone owns a big truck.
    This is what happens with regular roads. For the expressway, it is a toll road so they have the money to build tunnels. I always find the toll roads boring - they are like tunnels even when they are not, with huge concrete walls to contain noise. We usually drive the regular roads. Over mountains it is usually 1.5 lane - just room for two cars to pass each other but no line in the middle, and many many very tight turns.
    A recent road we drove while on a weekend trip. (Just regular map, not street view)
    Some of them are very scary, with no rails on the side and a sheer drop. So no one goes so fast on them. :D
    I apologize. I have no idea why it is a bad link... I will try in a different spot on the same road. Maybe you can see it now?
    Two lane road and one lane two-way road. If these do not work also, I suppose I will give up. :(
    Here, officially it is a limit. But it is very very rare to be pulled over for breaking the limit only. It is usually something in addition to another problem. Like, dangerous actions - plus speeding. Or as something to make it a heavier offense if there is an accident. If you were speeding at the time, it is far worse.
    I don`t think that in general cars are more narrow... Unless cars there are much wider than I thought. I think the 2010 Prius is on the narrow side of normal here. There are very narrow cars, but the mid size isn`t really. Also, semi-trucks will drive the same roads. I think the lane width is just large enough that a semi sized truck will fit perfectly into the lane without space leftover but without sticking out of the lane.
    On regular roads there will be special bending of street signs so that mirrors on large trucks will not bump them.
  14. Tideland Prius
    16,668
    I don't know what the % of the price here is made up of taxes.
    I know a friend of mine's parents have a 1995 Corolla in Japan with only 25,000kms!
    lol. Well they are some delivery options but most of the time, people do it themselves.
    :eek::eek::eek::eek::eek::eek::eek: holy crap. I don't think I've ever seen a road with that many curves in one screen
    Well I see the map, just no street view. The other google maps work, just not this site.
    Hmm, here I think the Prius is about the same width as a Corolla, maybe a tad wider.
    I mean, you have the Camry as well and it's a fairly large car (still called midsize here).
  15. Tamyu
    Tamyu New Member
    126
    42
    Nagoya, Japan
    Now a revisit to this thread. :)
    I finally finished the first tank of gas. 102km driven by my husband and 694km driven by me. Calculated from the first time we put gas in (I don`t know how much was in it when we picked it up at the dealer) it was 20.7kpl (Display was actually very close at 21.3).
    I am very pleased with a first tank getting that in cold weather! :love: Still with no long driving, only kind of short trips in the city with stop-and-go.
    After my husband came home from his business trip, I picked him up then he drove home...(After refilling the tank) The next trip we reset the trip counter and checked his mileage.
    For an 80 km trip he got 17.4kpl displayed - and he even started with the battery quite full from his drive home the night before. :eek:
  16. Tideland Prius
    16,668
    Nice! Getting any warmer?
