Difference in Wear Between Front L&R Tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Robert John, Sep 13, 2023.
  1. Robert John
    Robert John Junior Member
    64
    Montreal, QC
    I blew-out the front right tire on my Gen 2 in a serious pothole, so I bought a new replacement (same mfg, make, model, size, etc.) BUT... now there's a 13,600 km difference in wear between the two front tires.
    Q: Given the (slight?) circumference difference between the new R and 'old' L front tires, is that a problem for (the front differential or anything else)? I could put the new tire on the back R, and put the back R on the front R (so they're identical in wear), but I'll have to rotate the tires eventually.
    Thanks!
    I didn't find the appropriate place to post this question, so my apologies if it's in the wrong place.
  2. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    If you're not setting off your vehicle skid control or the other amber light traction control or whatever then you're okay put a 185 60 15 on that rim instead of the 65 and you'll see that light start to go crazy and you won't get above 63 mph pretty much ask me how I know.
  3. JC91006
    16,936
    8,647
    You won’t have any problems buying a new tire, your old tires have very little wear. Just buy new and enjoy
