Differences between Gen II and Gen III???
Discussion in 'Gen 3 Prius Main Forum' started by cinderfan, Aug 16, 2009.
  1. gene4655
    gene4655 Junior Member
    51
    Thanks to all those trying to help me out, but my complaint is with the so-called "smart key". I prefer just to keep it in my pocket, and with my Gen II Prius, I can do that and open the passenger door, or the driver door, or the hatchback door without taking the key out. I've looked in my Gen II Manual, and apparently this isn't possible. Small complaint, but still a nuisance.
  2. Tideland Prius
    16,682
    If you have a II or a III, then the smart key only works for the driver's side.
    Alternatively, just reach into your pocket and press the unlock button twice. You don't have to pull the key out, just feel for the button.
  3. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Are you referring to driver's only SKS vs. 3-door SKS? On the Gen II, if you have SKS (I'm not sure whether that was available for all packages) it would open all 3 doors. On the Gen III, it's driver's door only for package II and III I think. You have to have package IV or V to have 3-door SKS.
  4. gene4655
    51
    Thanks, Tideland, that's the answer I was looking for! Wish it were different, but...
  5. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    The 2010 handles better, from what I understand. (Bought a 2010, haven't owned one previously.) I've seen quite a few remarks that the steering has a much better feel, in particular.
    It's my impression that the Gen III is much more of a normal car, while the Gen II was more of an acquired taste. Just an impression from what I've read... and I certainly didn't consider a Gen II.
  6. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    Suppose you stepped into a Prius and weren't sure if it were a 2009 or a 2010. What would be the most obvious way to tell the difference? For instance, are the "eco", "Power" and "ev" buttons on the 2009, or just the 2010. Thanks.
  7. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    The dash/console/shifter layout is completely different between the two.
  8. Tideland Prius
    16,682
    np. Yeah it's a shame that they had to offer 1-dr SKS on the lower models. Hope they reconsider.
  9. jorbock
    jorbock New Member
    Longmont, CO
    I agree that the 3-door SKS on the IV and V should be standard on the lower models, but I don't find it a major inconvenience on my III model. It's a simple matter to program the SKS to unlock all doors when the driver's door is touched. On the lower models, with the SKS set for unlock all doors, when I need to get into the hatchback I simply touch the driver's door and then walk back to the hatch. This isn't quite as convenient as SKS on the hatch but it's far easier than digging for the remote, or opening the driver's door and pressing the unlock button. I generally find that I don't need SKS on the passenger door.
