Differences between years
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Sep 15, 2021.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Compiling differences between PP years. Pls review below and provide any additions, corrections, etc. Need help with last one. TIA.
    ENGINE OIL FILTER: early 2017s cartridge, later 2017-current spin on
    ENGINE OIL: 2017-19 0W20, 2020-current 0W16
    AVGMPG DISPLAY: 2017s maxed at 199.9, 2018-current max at 999.9
    TRIMS/GRADES: 2017-19 Plus, Premium, Advanced. 2020-current LE, XLE, Limited
    SAFETY: 2017-20 Toyota Safety Sense-P. 2021-current Toyota Safety Sense 2.0
    SEATING: 2017-19 4 seats, 2020-current 5 seats
    SUN VISORS: 2017-19 no extensions, 2020-current sun visor extenders added
    SEAT HEATER SWITCHES: under center console, 2020-current relocated by center cup holders
    ENTERTAINMENT: 2020 Apple CarPlay, Amazon Alexa, satellite radio, and two rear USB ports added to standard features list, 2021-current Android Auto only on LE trim
    PAINT COLORS: new for 2021, available Wind Chill Pearl replacing Blizzard Pearl White.
    INTERIOR COLOR: 2017-19 black/white, 2020-current all black
    HYBRID BATTERY WARRANTY: 2017-19 8 years/100k miles. 2020-current 10 years/150k miles
    DRIVER’S SIDE SWITCHES: 2017 all illuminated, other years ?????????
    john1701a likes this.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Sometime after 2018 Supersonic Red replaced Hypersonic Red in the US at
    least. The paint code did not change only the name.
  3. Marine Ray
    1,139
    949
    Sparks, NV
    Thx.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    According to @Elektroingenieur there have been three different parts listed for the driver side door switch panel.
    Question about 2021 Prius Prime Door Lock Switch | PriusChat
    I don't remember my 2017 model, but my 2020 model had all buttons illuminated. The OEM switch 84040-47090 MSRP $542.35, whereas, for my current 2021 model and I presume applies to 2022 model as well use the OEM switch 84040-48210 MSRP $238.94 which does not illuminate. Yep, $303.41 saving for Toyota for newer models.
    Marine Ray likes this.
  5. Marine Ray
    1,139
    949
    Sparks, NV
    To me not having them all lit up would be a safety concern.
  6. Salamander_King
    11,024
    8,978
    New England
    I don't miss it. I did not even know it was lit on my 2020 PP until I read the thread on it. I don't drive at night often. Even if I drive at night, I never look at the door switch to open the door or window.
    MTN and Marine Ray like this.
  7. Tideland Prius
    16,675
    The driver’s side window switches are illuminated on my 2018. Might’ve been removed for 2020 or 2021.
    The driver’s side power seat controls had silver trims on 2017 models but were removed for 2018.
    The base of the A pillar and the B pillar were piano black finishes on 2017-2020 models. 2021 swapped them to matte black (same as regular Prius).
    The interior door frames were covered in plastic for 2017-2019. They were removed in 2020+ so you can see the body paint colour. (And because of the angle of the interior door/window frame, you can see that exposed painted frame from the outside as well.
    Moonstone was black/white for 2017-2019 but light grey/white for 2020+ ( Moonstone is still offered in Canada).
    Rear 12V outlet replaced in 2020 with 2 USB-A charging ports (2.1A).
    In Canada, the top Prime trim level has a machined finished alloy wheel replacing the alloy w/ aerodynamic wheel covers.
  8. Tideland Prius
    16,675
    Supersonic Red is 3US. Hypersonic is 3T7. It was changed for 2020. Supersonic red is oh so slightly redder than Hypersonic but you wouldn’t be able to tell them apart unless they were parked side by side.
  9. fuzzy1
    10,690
    I believe vehicle load capacity (weight) also increased at the same time, but don't have numbers at hand.
  10. prime2020
    prime2020 Junior Member
    New York
    2020 Prius Prime
    The fuel gauge in my 2020 was pretty linear that it would drop about 1 notch every ~70 miles. In the 2021, the first notch takes almost 150 miles to drop and then goes every 60 after that.
  11. maiki
    maiki Member
    219
    35
    What about battery life? Has that not improved in more recent years? (Mine is 2018)
  12. Trollbait
    12,816
    Which battery? The 12V or traction?
    Reducing vampire drains from auxiliary systems while the car is off has helped with the 12V. The gen2 had a manual switch to trun off the SKS during long parkings, that is no longer needed. Moving the battery to the engine bay with the gen4 also means a larger battery.
    With gen1's going over 200k miles with the original traction pack, I didn't think that life was an issue.
  13. sparky12
    sparky12 Junior Member
    22
    Virginia
    2021 Prius
    XLE AWD-e
    One thing we've noticed is that with out '21 Prius AWD is that there is no spare tire. Didn't realize that until a few months after we purchased. Not sure when that change came about as until that vehicle we owned a 13 Prius V which we loved but it started having traction battery issues.
  14. Salamander_King
    11,024
    8,978
    New England
    For this thread which is about Prius Prime, the models never had a spare tire since the initial 2017 models. In fact, that was also true for Gen1 PiP. This was due to lack of under deck space where usually a spare tire is stored was used by the bigger traction battery. For your Gen4 AWD-e model, Toyota had to eliminate the spare tire due to the location of the rear motor for AWD-e. I believe regular Gen4 Prius except for the base model (LE?) do not come with a spare tire, but they do have a space for the tire under the deck, so you have the option of adding it.
