Different Offset alloy wheels
Discussion in 'Prius c Accessories and Modifications' started by Ivan Quinones, May 30, 2013.
  1. Ivan Quinones
    Ivan Quinones Junior Member
    I found some 15" x 6.5" alloys which claim to fit the Prius C but have 42mm offset instead of 40. How critical is this? Would I need spacers?
  2. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    Those will fit fine without spacers.
  3. Ivan Quinones
    Since the website recommends them for the Prius C I figure they probably would no cause any rubbing, but how would it affect the handling, tire wear, etc? I have found wheels that have 42, 40 and 38 mm offsets so there must be a technical reason why they give them such an exact number.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    If you look behind your wheels on the front, the strut tower is about a hands width from the tire. If you choose an incorrect backspacing, you will get closer to this. When the tire flexes from road undulations, the tire will rub on this tower.
  5. flotowngtm
    flotowngtm Junior Member
    42
    22
    Thats a change of 2mm, I can assure you thats its not going to hurt anything!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! The manufacture gives you a little more wiggle room than 2mm.
  6. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)Agree.
  7. mahout
    mahout Active Member
    655
    116
    NC
    My OEM wheels are 45mm offset and we mounted 40mm with 195/55x15 tires.
    There should no problem mounting 42 mm offset wheels as long as you don't exceed 195 section tires; you can indeed use spacers, say 1/4" or 6mm, to reduce the offset by 6 mm, or 1/8" or 3 mm, to reduce the offset by 3 mm.
    DO NOT EXCEED 1/4" spacers. And if you increase the weight of the tires you should slightly decease the tire diameter so you won't harm your acceleration or mpg. Use tirerack.com to check the weights of tires.
  8. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Yes, he should be fine... I was just saying to make sure not to pick one that is outside that wiggle room.
  9. orenji
    orenji Senior Member
    5,884
    3,486
    Can some one tell me if I switch to wheels with the same stock tires that came with me C, will there be any issue?
    New wheels are: Offset 35MM, 4X100 bolt pattern, 15X5.5 Wheel.
    I am concern with the offset as is seems stock is 38.5 MM.
  10. B2FiNiTY
    979
    226
    That will be fine.
    I ran 15x7 +41 with the stock tires
  11. orenji
    5,884
    3,486
    It will bring the tire and wheel out more not in, right?
  12. B2FiNiTY
    979
    226
    Yes. Slightly more out. With that width and offset though, not by much.
  13. orenji
    5,884
    3,486
    Thank you
