Difficulty Reaching, Pulling Down the Hatch
Discussion in 'Prime Main Forum (2017-2022)' started by Arthur Adelman, Apr 22, 2018.
  1. Arthur Adelman
    Arthur Adelman New Member
    Armonk, NY
    My wife drives our recently purchased 2017 Toyota Prius Prime Advanced. She is 5 feet tall and has trouble comfortably reaching and pulling down the hatch of the cargo area after loading it with groceries, etc.
    Can the height it opens and/or the force necessary to close it be adjusted, or if not, how might I improvise something to make it easier for her to 1) reach the pull-down handholds 2) pull the hatch down, i.e. ease the required force.
    Thanks.
    Art A.
    Shaunius likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  3. cramer77
    cramer77 Junior Member
    22
    Markham Canada
    2018 Prius Prime
    Touring + Tech
    Dual purpose device..storage and height enhancer.
    FYI Tapatalk isn't showing the picture, but other browsers are.
    #3 cramer77, Apr 22, 2018
    KrPtNk likes this.
  4. VVTiBob
    VVTiBob Member
    45
    29
    C871E77F-AD44-4146-A3B9-C1A7B95910AF.jpeg C871E77F-AD44-4146-A3B9-C1A7B95910AF.jpeg Sounds like a pull down strap and some ingenuity on your part.
    Shaunius and WilDavis like this.
  5. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I'm also short and cannot reach the hatch at all when it's fully open. I have basically a stick with a hook on it that i use to close it. You have to trigger the hatch closed latch, then use the hook to pull the hatch down. It's a pain, but I used that same stick on my 2010 Prius for years. I've threatened to mod it for years, but never really found a good solution. I almost bought a C-Max to get the powered hatch..
  6. VVTiBob
    VVTiBob Member
    45
    29
    I’ve also been looking for an aftermarket power liftgate kit for the Prius Prime. Haven’t been able to find one for the Prime but they have them for the RAV4 as well as other cars. I suppose it has to do with the total number of models sold RAV4 is in the neighborhood of 450,000 units whereas Prius is not nearly as many.
    UPDATE - Sunday, 4/22/18 2:15 Pacific Time
    I have found a vendor who may have a power liftgate that works with Prius Prime. I’ve sent an inquiry and waiting to hear back.
    #6 VVTiBob, Apr 22, 2018
  7. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Maybe just maybe you could get the really good I mean I'm talking industrial heavy duty that will never come off tape and stick a really good rope so she can pull it down
  8. EyePrime
    268
    115
    2018 Prius Prime
    And on both right and left side of the hatch, they have little button kinda hook (On the Hatch) That are meant for the soft cargo cover (NOT HARDCOVER) and could maybe tie a strong rope onto it
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    The arrows in the picture point to the handles for the rear hatch. Are these what she cannot reach?
  10. VVTiBob
    VVTiBob Member
    45
    29
    There is also this genuine Toyota product.
  11. VVTiBob
    VVTiBob Member
    45
    29
    By the way, in case you are wondering, on the Amazon Japan website the word-
    bakkudoasutorappu - translates to back door strap.
  12. Mendel Leisk
    42,369
    I keep thinking: if a strap is long enough to help, is it also going to get in the way when the hatch closes?
  13. Bob Comer
    708
    460
    It depends on where you put it. Something closer to the middle of the hatch might work. The trick would be to get as close to the center of the hatch that you can while still being able to pull it down.
  14. VVTiBob
    VVTiBob Member
    45
    29
    The genuine Toyota part come with an installation template to avoid having the strap interfere with the closing of the hatch.
  15. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Look on the sides of the hatch when it's open. You'll see the heads of bolts there that are not used. I think the struts could be mounted to the bolts here to limit the opening height. If you try it, be sure to use a strong helper to hold the weight of the hatch when the two struts are disconnected.
  16. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I bought a pack of bungee cords at Dollar Tree, and the 12" size is just right. I just need to spend a little time with a pair of pliers to bend the hooks so they will stay in place around the ends of the strut. This will effectively lower the height the hatch can raise.
  17. Shameless
    Shameless Member
    71
    38
    Western Massachusetts
    #17 Shameless, Apr 24, 2018
    BillKoz, pilotgrrl, benagi and 4 others like this.
  18. VVTiBob
    VVTiBob Member
    45
    29
    Excellent, but the late seventies are asking you to return their disco platforms, they were only a loan.:LOL::p:D(y)
  19. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    This is the kind of question likely will get some silly answers but it deserves a serious solution.
    Being five feet tall is not a disability, but but in this situation it creates a problem similar to those faced by many people with disabilities. (Having my left arm in a cast for six weeks made me appreciate the need to come up with creative work-arounds just to accomplish simple things like pulling a car door closed.)
    I found this handy tool which is made for people who are physically impaired to assist with the simple task of getting dressed. It's an excellent device for reaching and pulling things in addition to clothing... such as car doors, etc. I now keep one in the back of the car with the snow brush.
    It is available from Amazon and from other places. The hooks are firmly attached and the plastic coating does a pretty good job of not scratching surfaces.
    I'm sure that, if you wanted, you could make something like this out of hardware store parts.
    heiwa, Bob Comer and Prodigyplace like this.
  20. Bob Comer
    708
    460
    Well said Old Bear!
    fwiw, the stick and hook thing I use is very similar to that only home made. I'm short and disabled, so it really is a serious problem to be able to reach some things. You haven't felt frustration until you go to a store and what you need is on the top shelf and there's nobody else around to beg for help.
