Difficulty Reaching, Pulling Down the Hatch
Discussion in 'Prime Main Forum (2017-2022)' started by Arthur Adelman, Apr 22, 2018.
  1. A Prime Factor
    A Prime Factor Formerly "I want my PHEV"
    340
    171
    Madison, WI
    Pictures, please.
    It is quite a reach. Impossible to close the hatch with one hand, so a problem if carrying something.
  2. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    It's finally my weekend, so I'll have a chance to play with it. And I can take pictures, too.
  3. Sailor1942
    Sailor1942 New Member
    2018 Prius Prime
    My wife has the same problem. She is 4'11 and cannot reach the handhold on her 2018 Prius in order to close the hatch. After Toyota refused to do anything about it, and even suggested that she should carry a foot stool, I did some research and found a great shop in Carlsbad, CA that carries a shorter strut specifically made for the Prius. We took the car over, purchased a pair of struts,
    Model *-*PM3811-A and had the owner install them for us. Now my wife can easily close the hatch. The new struts cost us $47.63!
    Here is the info for anyone interested:
    LiftSupports Depot
    2345 Camino Vida Roble
    Carlsbad, CA 92011
    760-744-2956
    UN4GTBL, frodoz737, Curlyone and 3 others like this.
  4. Mendel Leisk
    42,313
    Something like that might prevent garage door collisions too.
    Prodigyplace likes this.
  5. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Has anybody adjusted the hatch opening height the way Toyota intended?
  6. Trollbait
    12,817
    Maybe if the dealer knew about it.
  7. Mendel Leisk
    42,313
    There is a procedure?
  8. Kedavis
    Kedavis Member
    San Diego, California
    2019 Prius Prime
    I'm on my 4th Prius. I'm 5'11" and have no trouble reaching the hatch door, but getting it to close is more difficult than my 3 previous cars. Even if you push it as you are closing it there's not usually enough momentum for it to latch. I usually have to pull it down, then push it closed. Even then I often have to open and re-close it for it to latch.
  9. Mendel Leisk
    42,313
    Sometimes there's little rubber bumpers that are height adjustable; with them you can try screwing them in slightly, which reduces their height, makes closing easier. Not sure if this is applicable.
    Or a hatch gasket that's not completely pushed down?
