Dimmer on bright even when sw is disconnected
Discussion in 'Gen 2 Prius Main Forum' started by Richard Leffler, Aug 29, 2019.
  1. Richard Leffler
    Richard Leffler New Member
    Ganville Ohio
    Three Touring
    My 2007 dash lights are on bright all the time. I just replaced the 4 button, no camera, no navigation, MFD and it seems like it happened at the same time...not sure. I even replaced the dimmer switch with another ... no difference. I pulled the MFD out to check the wiring.. everything is tight and the MFD works as expected. I even unplugged the dimmer switch and it was still bright. any ideas?
    Thanks in advance....
  2. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    It seems like somehow your dimmer switch is no longer part of that circuit.... Perhaps chat with the people who repair MFD's on here and see what they say?
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Did you get an MFD with the same part number? I believe they were upgraded starting in 2006. If you have one from an older model that might cause problems.
    PriusCamper likes this.
  4. Richard Leffler
    Ganville Ohio
    Three Touring
    Yes, I got the same part number (ends in 81) thanks for the thought
    Skibob likes this.
