disable backup beep prime LE 2020
Discussion in 'Prime Main Forum (2017-Current)' started by JOLO, Dec 1, 2019.
Tags:
  1. JOLO
    JOLO New Member
    LA
    2020 Prius Prime
    Tried a few things posted online for regular Prius and didn't seem to work. Hate the backup beep....thanks for your help!
  2. schja01
    schja01 One of very few in Chicagoland
    1,383
    951
    Chicagoland
    2018 Prius
    Officially there is no setting to totally disable. Your dealer can set it to a single beep. You can do it yourself with an OBD2 dongle and app like Carista. Some apps are free some cost a few dollars.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    9,435
    11,512
    Tampa, FL
    Welcome. I hope you like your fantastic new car as much as I like my fantastic not as new car. Great as it is, it does have a few annoyances. Some you can change via the operator interface, some need a little equipment, and some you're stuck with.
    I've had three Gen 2, a PiP, and a Prime. As @schja01, said, the backup beep can only be changed to a single beep. No way to disable it. And there's also no way to change it without using a phone app with an OBDII dongle or, better yet, Techstream. There are countless threads here about both methods.
    You'll find that there are tons of things that can be customized that way.
    Randi likes this.
  4. JimboPalmer
    12,280
    6,653
    Greenwood MS USA
    The dealer can set it to a single beep, ideally for free. I would read the owner's manual chapter on customization and do them all at once.
  5. Salamander_King
    Salamander_King Senior Member
    7,899
    6,322
    New England
    2020 Prius Prime
    I just bought Carista OBDII adapter on Amazon. Currently 30% off. http://www.amazon.com/gp/product/B00YVHGTBM/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    The app comes with 30 days trial subscription to enable special customization for PRIME. You can change everything you want to change during that period, and cancel the subscription. At $14, it's cheap enough might be better than going back to a dealer.
    Toyota Prius PHV/Prime/V 2nd gen | Carista OBD2 supported vehicles | See what’s available for your car - Carista
    Here is the complete list of what you can customize PRIME with Carista
    Dings & Warnings
    Reverse-gear beep
    Beep once / Keep beeping while in reverse
    Seat belt warning ding (driver)
    Enabled / Disabled
    Seat belt warning ding (front passenger)
    Enabled / Disabled
    Seat belt warning ding (rear passengers)
    Enabled / Disabled
    Ding when key is left in the car
    Enabled / Disabled
    Ding when key is out of the car and ignition is on
    Yes / No
    Ding when headlights are left on
    Yes / No
    "Master caution" light
    On / Off
    Remote low battery warning
    On / Off
    Driver Assist
    Pre-Collision System (PCS) sensitivity: remember last state
    Enabled / Disabled
    Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on
    Far / Remember last distance
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on
    Heater & A/C
    Remote-start A/C from remote via…
    Off / Double long press / Long press / Double click / Single click
    Remote-stop A/C from remote via…
    Auto-turn on A/C when AUTO button pressed (if needed)
    Yes / No
    Auto-turn on recirculate mode when A/C is on
    Yes / No
    Open vents to outside air when ignition is turned off
    Yes / No
    Auto-increase blower speed when front defroster is on
    Yes / No
    Open air flow to footwell when AUTO button pressed
    Yes / No
    Ambient temperature calibration
    -3°C / -2°C / -1°C / Normal / +1°C / +2°C / +3°C
    Fan speed reaches its target…
    Slowly / Normally / Fast
    A/C ECO mode
    Enabled / Disabled
    A/C compressor noise reduction
    Enabled / Disabled
    S-Flow function
    Enabled / Disabled
    Instruments: Displays & Nav
    Instrument lights dimming sensitivity
    Darkest / Darker / Normal / Lighter / Lightest
    Instrument lights restoring sensitivity
    Engine start indicator
    On / Off
    Speed limit in dashboard
    On / Off
    Display odometer after ignition is turned off for…
    30 seconds / 1 minute / 10 minutes / Off
    Lights: Automatic
    Automatic High-beam System (AHS)
    Enabled / Disabled
    Auto headlights activation threshold
    Headlights in residential area mode
    Yes / No
    Lights: Exterior
    Lane-change turn signal auto-flasher count
    Off / 3 flashes / 4 flashes / 5 flashes / 6 flashes / 7 flashes
    Turn signal click volume
    Low / Medium / High
    Coming-home lights duration
    30 seconds / 60 seconds / 90 seconds / 120 seconds
    Lights: Interior
    Interior light control
    Enabled / Disabled
    Turn on interior lights when you shut off engine
    Yes / No
    Turn on interior lights when you unlock doors
    Yes / No
    Turn on interior lights when smart key in range
    Yes / No
    Dim interior lights after…
    7 seconds / 15 seconds / 30 seconds
    Interior footlight (bright when doors open, dim when driving)
    Yes / No
    Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
    Yes / No
    Locking: Automatic
    Wireless door locking
    Enabled / Disabled
    Re-lock doors automatically if you unlock, but don't open a door within…
    30 seconds / 60 seconds / 120 seconds
    Locking: Beep & Blink
    Blink turn signals when locking/unlocking with remote
    Yes / No
    Locking: Doors & Alarm
    Max number of consecutive lock/unlock cycles via touch sensor
    Unlimited / 2 times
    Warn (beep) when door can't be locked because it's still open
    Yes / No
    Warn (beep) when a window is still open when locking doors
    Yes / No
    Warn (beep) when sunroof is still open when locking doors
    Yes / No
    Locking: Smart Key
    Stop monitoring for car key signal after…
    0 - 5 days
    Touch-to-unlock-doors minimum duration
    Off / Short / Medium / Long
    After locking with smart key, don't allow re-opening within…
    0.5 seconds / 1.5 seconds / 2.5 seconds / 5 seconds
    Smart key location to start car
    Front seats / Anywhere in vehicle
    Open trunk via smart access button
    Disabled / Double click / Long press
    Mirrors
    Auto fold side-view mirrors (req. power folding mirrors)
    With ignition / With door locks / Disabled
    Windows & Sunroof
    Open windows and sunroof via long-press on remote
    On / Off
    Close windows and sunroof via long-press on remote
    On / Off
    Open windows and sunroof by turning and holding key in door lock
    On / Off
    Close windows and sunroof by turning and holding key in door lock
    On / Off
    Beep when opening/closing windows with remote
    Yes / No
    Open driver's window using single button press
    Yes / No
    Close driver's window using single button press
    Yes / No
    Open passenger's window using single button press
    Yes / No
    Close passenger's window using single button press
    Yes / No
    Open rear left window using single button press
    Yes / No
    Rear-left window single-touch-close
    Yes / No
    Open rear right window using single button press
    Yes / No
    Rear-right window single-touch-close
    Yes / No
    Passenger window single-touch-open from driver's switch
    Yes / No
    Passenger window single-touch-close from driver's switch
    Yes / No
    Rear-left window single-touch-open from driver's switch
    Yes / No
    Rear-left window single-touch-close from driver's switch
    Yes / No
    Rear-right window single-touch-open from driver's switch
    Yes / No
    Rear-right window single-touch-close from driver's switch
    Yes / No
    Wipers & Washer
    Automatic wipers (using rain sensor)
    Yes / No
    schja01, engunneer, MTN and 5 others like this.
  6. jerrymildred
    9,435
    11,512
    Tampa, FL
    That's a nice list, @Salamander_King! I just made it into a pdf and saved it with my pdf manuals. (y)(y)(y)
    Salamander_King likes this.
  7. Salamander_King
    7,899
    6,322
    New England
    2020 Prius Prime
    I just copied from the Carista site Toyota Prius PHV/Prime/V 2nd gen | Carista OBD2 supported vehicles | See what’s available for your car - Carista
    I have not studied this list carefully, but I first thought the first choice on the left is the default setting, but it's not. (see EDIT below) I am also not exactly sure which items are operator switchable without using this app. Also, there seems to be a few items listed that does not apply to US model PRIME, like power folding mirror. Does this option exist in other market? I just bought the dongle, but don't intend to start the free 30 days trial, until I am ready. Don't want to end up paying annual subscription fee of $40.
    EDIT: Looking at the first two items on the list, the default is not the first choice on the left always. Red is default. So, I don't know what default settings are on this list. It would be very nice to know default settings for all of those items.
    Reverse-gear beep
    Enabled / Disabled
    #7 Salamander_King, Dec 2, 2019
  8. JOLO
    JOLO New Member
    LA
    2020 Prius Prime
    Thank you everyone! I guess I’ll buy the OBD connector and the app, thanks. I was also wondering if there is a way to disable the warning screen about distracted driving when the car starts every time?
  9. schja01
    1,383
    951
    Chicagoland
    2018 Prius
    Wait a few seconds it goes away on its own.
  10. CharlesH
    2,648
    1,075
    Roseville, CA
    In addition to setting the above "dealer" options, the Carista app can also read out the individual tire pressures from the TPMS sensors, which for some reason Toyota has chosen to not put into the Prius displays. Even my son's 2008 Highlander does that.
  11. thymara
    thymara Junior Member
    59
    Edmonton, Alberta
    2020 Prius Prime
    Dr. Prius app has an option to disable the beep. Has anyone tried this app and does it work?
    I consider the backup beep dangerous since beeps from people or vehicles crossing behind may be muted or otherwise not even noticed. I know when I'm in reverse, I'm more concerned about people/traffic
  12. schja01
    1,383
    951
    Chicagoland
    2018 Prius
    The backup beep is customizable by a dealer or a myriad of apps via the ODB2 port. I personally have it set to a single beep. Problem solved.
  13. jerrymildred
    9,435
    11,512
    Tampa, FL
    Lots of people are using Dr. Prius. I have it but since I have the car all set up, I rarely connect to it.
  14. thymara
    59
    Edmonton, Alberta
    2020 Prius Prime
    The Dr. Prius website says the following which suggests I should continue looking although, I suppose, a test won't hurt
    2017-2019 Prius Prime Plug-In Beta Support
    Mine is a 2020 and I tend to avoid beta stuff.
    Got brave and tried it out. With Dr. Prius connected beep can be eliminated. Next task will be to see if it's eliminated when not using Dr. Prius. Might be a trip to the dealership yet, but only if there's a more important reason.
    Thanks jerrymildred
    #14 thymara, Mar 26, 2020
  15. jerrymildred
    9,435
    11,512
    Tampa, FL
    Well, reduced to one beep, anyway. I'm sure it'll stick. I didn't use that app to customize mine because I have Techstream. It's the big gun. It's what the dealers use. Lots of threads around here about it if you're interested. But probably the simplest setup, although not the cheapest is Carista. It uses a bluetooth OBDII reader same as Dr. Prius, but you rent the app. I HATE renting software, but it is really good stuff.
    thymara likes this.
  16. Yamsta
    Yamsta New Member
    Maryland
    Apologies for reviving this old thread, but is there a general consensus on which tool + app works best on the Prime? One month of ownership and the backup beep is becoming unbearable. I recently ordered an obd2 tool recommended by the Dr Prius site and downloaded the app but haven't tried using it yet. The site doesn't have mention of 2021 model year but I figure it should work? Any updates on carista? I don't mind paying one time for software, but really don't like the subscription model unless I'm using it regularly.
  17. jerrymildred
    9,435
    11,512
    Tampa, FL
    If all you want to do is disable the reverse beep, you already have a tool that'll do it with the Dr. Prius app and the OBDII adapter. However "disable" is a little misleading. You can leave it at the factory setting of continuous, or you can change it to one beep. But you can't make it not beep at all. :) LOL!!! I'm gonna leave that last part there about the one beep because it's so weird that I said that exactly one year ago in this thread.
  18. Yamsta
    Yamsta New Member
    Maryland
    Thanks, ok what about other car functions mentioned above? I'm anticipating maybe changing the headunit down the line and I would like to possibly control the few car settings that are in the current head unit. Thanks.
    #18 Yamsta, Mar 26, 2021
  19. jerrymildred
    9,435
    11,512
    Tampa, FL
    You can only change a few things with Dr. Prius since that's not its main purpose.
    Carista is more aimed at customizing and does a lot more. Any customizing that can be done in the HU should be available in Carista plus a whole lot more. If you look at the list of things that can have their settings changed, you'll see that most of them require a "dealer" ... or Carista, Techstream, etc.
    But you might sacrifice some of the Prius specific controls with a 3rd party HU. Maybe someone who's made that change can shed some light on what goes on in that arena.
  20. SeattleBebop1
    SeattleBebop1 Member
    123
    73
    Seattle
    I think one beep is reasonable! It *is* a safety feature at all. I was glad it was easy to use Dr. Prius to modify the beep, though, because the constant beeping gives me low-grade anxiety (which makes things *less* safe).
    Dave deBronkart and jerrymildred like this.
Loading...
