Disable "key not detected" beep
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Globe199, Jan 5, 2015.
  1. Globe199
    Globe199 Junior Member
    Twin Cities
    I have a 2011 Prius Three. After about a month of owning it, I had the dealer disable the back-up beeping so it only beeps once when backing. I'd like to disable the "key not detected" beep. Anyone know if this is possible? I googled around and couldn't find anything. Thanks.
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I don't know the answer but are you sure want to do this? I mean, even with the one beep, twice, I dropped off my wife and she left with the keys in her purse. I was only dropping her off at the front of the store. It would be mighty inconvenient if it was the airport and going home for the spare wasn't my next destination.
  3. Globe199
    Twin Cities
    A message on the display is enough for me. In the morning, we are warming up the car while opening and closing doors, and the constant beeping/nagging has gotten to be enough. I'm guessing that if it can be done, I'll need an OBD tool.
    There is one thing I feel the car SHOULD beep about, and that is if the emergency brake is on and you shift into D. Hilariously, that is the only thing it doesn't nag you about.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I have gotten used to closing the door(s) most of the way, but not completely to avoid the beeping.
  5. JC91006
    16,936
    8,647
    This is a safety feature that you cannot disable legally. I guess it'll stop nagging you once you're dead from not turning off your car 1 time in the garage. The carbon monoxide will do the trick in stopping the nag.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Why not just throw the key fob in the front seat until you are ready to get in and drive ?
    Toyota is not going to let you disable this beep.
  7. yothere
    yothere Junior Member
    22
  8. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    please details/
    where in techstream would I find this setting?
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    Must be talking about changing the reverse beeping to single beep.
  10. yothere
    22
    Not sure, I haven't done it myself yet, but ordered this after reading a thread where someone said they did it.
  11. StarCaller
    1,284
    733
  12. yothere
    22
    When I hook it up I'll take a look and repost. I thought I saw it, but I may be remembering wrong.
