Disabling Auto Door Locking / Unlocking
Discussion in 'Gen 3 Prius Main Forum' started by stream, Jun 3, 2009.
  1. reddavid
    reddavid Junior Member
    37
    Wayne, PA
    Wanted to turn off the automatic door lock function and enable the lock at 17 mph. Had to actually do both steps (in sequence).
    1. Disable automatic door lock when shifting out of park.
    2. Enable automatic door lock based on speed.
    Took a bit of trial and error, but it works!
  2. Frolix
    Frolix Junior Member
    45
    22
    Here
    None of hose things work on my Euro Prius. Aaaargh.
  3. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    You are right, the EU manual doesn't mention this procedure anyway. When I tried to setup it up with techstream/tactrix the lock settings are empty.:(
  4. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Nothing available either on the German version.
  5. RobH
    RobH Senior Member
    2,376
    988
    70
    Sunnyvale, California
    You might try setting up Techstream in North American mode. I think some of the menus are different. Just because Techstream can't do something it doesn't mean the car can't.
  6. Rajitha Jayasekera
    Rajitha Jayasekera New Member
    Sri Lanka
    I know this is an old thread. Hope you all can help me.
    Even I cannot get this worked on my Prius III gen. Mine was imported from Japan & the option is there on the manual.
    The doors won't lock when exceeding the speed limit, wont unlock when i put it to P, or wont lock when I put it to D from P.
    Any help would be much appreciated.
