Disabling Smart Key System in Camry
Discussion in 'Toyota Hybrids and EVs' started by Tideland Prius, Oct 28, 2006.
  1. Tideland Prius
    16,073
    Precondition:
    Power switch OFF, driver side door closed and unlocked.
    a) Unlock the driver door once with the UNLOCK switch of the electrical key.
    b ) Open the driver door within 5 seconds.
    c) Unlock the driver side door twice with the UNLOCK switch of the electrical key within 5 seconds.
    d) Repeat open -> close twice for the driver door within 30 seconds, and open again.
    (Driver door: OPEN -> close -> OPEN -> close -> OPEN)
    e) Unlock the driver door twice with the UNLOCK switch of the electrical key within 5 seconds.
    f) Repeat OPEN -> close once for the driver door within 30 seconds, and open again.
    (Driver door: OPEN -> close -> OPEN)
    g) Close the driver door within 5 seconds.
    When the electrical key cancel is activated, the wireless door lock buzzer sounds TWICE.
    To return to the original condition, perform the procedures again. When the original condition is returned, the wireless door lock buzzer sounds ONCE.
    Source: Hybridcars.com forum
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Yuck! What a PITA! Do you have a full size 12v battery on the Camry? Maybe they just figure it would take several weeks to drain the 12v w/ the SKS if it's a full size battery.
    But yea, a switch makes a lot more sense.
  3. Gabriel Barp
    Gabriel Barp New Member
    Paraguay
