Disabling traction control?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Coyotefred, Nov 7, 2012.
  1. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    Has anyone confirmed whether the procedure below (from another post referring to a Gen II I believe) works with the PiP for a situation where you might want to try disabling traction control (snow, mud, etc.)?
    These steps must be completed within 60 seconds.
    Step 1: Set the ignition switch to ON, not READY. To do this press the power button two times, without pressing the brake pedal.
    Step 2:
    While the transmission is still in park (P), fully press the gas pedal two times.
    Step 3: Apply the parking brake to ensure that the vehicle will not move during this step. Put the transmission in neutral (N) and fully press the gas pedal two times.
    Step 4: Put the transmission back in park (P) and fully press the gas pedal two times. The car will display “!Car!” in the upper left corner of the LCD screen.
    Step 5: Press the brake pedal and turn the ignition switch to the start position, without going back to the ready position, to start the engine.
    If these steps are followed correctly, the vehicle will start with the traction control system defeated.
  2. lensovet
    2,614
    496
    Burlington, NJ
    wow, i particularly like the "!Car!" message
  3. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    Anyone?
    I just tried this on my vehicle and I get hung up on Step 3. I can't shift it into N. I get a two-beep warning but the vehicle stays in P. But I may be doing something incorrectly...just curious whether anyone has had success with this...?
  4. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    Are you saying that you were able to do the procedure and get this message or ??? Thanks-
  5. lensovet
    2,614
    496
    Burlington, NJ
    no i just think it's a funny indicator. haven't tried it.
  6. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I'm assuming you are holding it in N for a second or so? I noticed it won't shift into N otherwise (at least the 1 time I tried).
  7. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    Press and hold brake when switching into neutral.
  8. lensovet
    2,614
    496
    Burlington, NJ
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Agreed. You must hold the shifter in the neutral position for a couple of seconds before it will switch to that setting.
    lensovet likes this.
  10. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    After following the procedure on my Prius v (wagon), I pressed the brake and start to get into ready mode and the slip indicator light and Hybrid System Warning Light (no buzzer) were lit up. I didn't have any snow or ice to spin my wheels on (yet), but the lights were a good indication that I had turned off traction control.
    I took me a couple of tries getting into neutral as just switching or holding the joystick in neutral did not work. Then I remembered that I have to hold the brake to get it shift out of park normally. Maybe it is different for the Prius v than for the hatchback.
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Ahh, I've only ever tried to shift to neutral while driving. Never while in park.
  12. lensovet
    2,614
    496
    Burlington, NJ
    yeah i mean that's how it always is. you can't shift out of park without having the brake pedal down because otherwise the car would just instantly start rolling.
  13. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Yeah, it works, needed it today. You get "Maintenance Mode" on the display. If you clear it, 5 seconds later, it pops up again. Stoopid snow and ice.
  14. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    Thanks for confirming this. I'm pleased to say I haven't had the need to actually do this with my snow/ice driving the last few weeks. I have Michelin X-Ice snow tires running which I think makes the biggest difference, but I'm very impressed with the PiP in snow thus far. Obviously with its low ground clearance it would be a poor choice to bust through significant accumulations, but for packed snow and ice/slick conditions the PiP + X-Ice has been a very reliable combination...
  15. Scargod
    Scargod Junior Member
    65
    16
    Southern Central Connecticut
    Today I am asking about defeating the Traction Control on a different thread. Here is a new post from it: Traction control procedure | PriusChat
    where cwerdna | PriusChat says that you should not do this according to the manual.
    How many of you have actually used the procedure and how many have had any ill-effects from disengaging traction control?
  16. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I disengaged the traction control long enough to clear the path that where I was stuck. It was so bad, that the car was in drive, and going backwards because the wheels wouldn't spin.
    Once I got to the top of the hill, I reset the car to engage it again.
