Disappointing free NAV upgrade
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bradnunn, Dec 2, 2004.
  1. bradnunn
    bradnunn Junior Member
    Tennessee
    I recently got the free Nav update DVD. The only difference I noticed was that I had to reset my home region after the upgrade. Otherwise I have noticed nothing different. I had hoped that the upgrade would allow for route guidance via smaller roads in rural areas. As before, the roads are on the map and the names even display correctly however, route guidance will not direct you down these roads even if they would provide a considerably shorter route. My 2 year old $400 Garmin handheld will route me over these roads. I had hopes that the upgrade would address this issue. No such luck.
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I noticed my newer DVD actually made my current neighborhood *less* accurate, however I'm okay with that since everything else is generally more complete.
    AZ still has alot of changing roads which this DVD can't possibly cover as this data is probably still ©2003 if we're lucky.
  3. tntna
    tntna New Member
    131
    Central OH
    I've only had the car a week and am not a nav expert, but I remember seeing settings for things like toll roads, etc that could be turned on and off. I'm wondering if there isn't a setting somewhere that's telling the nav system to only use major roads.
  4. tntna
    tntna New Member
    131
    Central OH
    I actually was showing a coworker the car and took a quick look at some of the settings. I didn't see anything that might be causing the nav system to avoid using backroads.
  5. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Could somebody please try to locate a Walgreen drugstores in Columbia, SC and tell me if any are there now?
    I tried it with my 3.X and was told I'd have to drive 80+ miles. Funny, the one I did go to was 3 miles away...
  6. aforkosh
    aforkosh Active Member
    403
    253
    Oakland, CA
    2023 Prius
    I had the Nav upgrade done on Friday. The errors that I had noticed on the previous edition (missing the freeway onramp near my house, mislocating a restaurant in Mill Valley, CA, missing the shortest route from Oakland to Mountain View) are all fixed. Also, my home location now has the correct address associated with it (I had set the location as a mark with my parked in its normal location). Also, the "Do not enter" symbol on the close up intersection map now only shows only for roadways that truly one-way, rather than for every direction you are not supposed to turn.
    However, the new version now seems to interpret more road bends as full turns, and the voice sometimes indicates a turn when you should go straight. For example, the entrance to the east portal of the Caldecott Tunnel was considered a right turn, even though I was actually continuing straight on Highway 24 (and I was not exiting for several miles). The same was true for some freeway onramps where the correct action was to continue accross an intersection (shown correctly on the diagram) but the voice navigation instructed a left or right turn. All in all, it seems like a worthy free upgrade--just don't rely totally on the voice navigator.
    I waited until I got the letter from Toyota about the upgrade. When I requested the upgrade from the dealer (using the LSC-40) designator, they called me back to confirm that I wanted the paid upgrade. I brought them the dealer's memo for the work that I had downloaded from Priuschat, and they said they still hadn't gotten it from Toyota. Anyway, they kept a copy of the note, using it to order the upgrade. It was ready for me in two days.
  7. Tobalt
    Tobalt New Member
    47
    Huntsville, AL
    Free Nav Update? Did I miss something here?
  8. tag
    tag Senior Member
    2,526
    Chicago
  9. tag
    tag Senior Member
    2,526
    Chicago
    I don't know how many there are in Columbia, but I was able to find one with the new DVD (v4.2).
  10. mikepaul
    1,763
    Columbia, SC
    Well, the only one I knew of was on Forest Drive, but if you found even one it's a step-up from *my* NAV. Thanks.
    I *guess* if I ever get the letter, I'll follow through...
  11. tag
    tag Senior Member
    2,526
    Chicago
    Yep, the one I was able to locate was on Forest Drive.
