Disassembling a very Rusty intake to clean manifold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mellyman666, Oct 9, 2023.
  1. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
    Hi!!
    I googled and searched the forum already; saw the steps to removing this pipe that’s connected to the intake manifold cover, but every situation had a nice good looking clamp. So if anyone has some tips or had this issue, let me know. I want to try to not break the clamp since the clamps range from 20-50$ to replace (each ). And was looking to soak my manifold (hence why I want to remove all this).
    Here are pics; I have doused it in WD40, the clamp opens at the prong part, but doesn’t really move so I can’t imagine that I’ll be able to pull the pipe off.
    Also can’t seem to disassemble without removing this because bolts are inaccessible; they’re covered by the pipe clamp
  2. Mendel Leisk
    42,347
    They're a lot cheaper here ($2~3 CDN apiece):
    https://www.amayama.com/en/catalogs/toyota/prius/3-hatchback-right-xw30-2009-2830/engine-fuel-system-and-tools-1/air-cleaner-27
    I've ordered from them several times; never any problems, nor extra duty (at least on the small items I've got, one shipment close to $100 CDN). You will incur a shipping charge. Ensure they're all from one source (typically either Japan or UAE), to not have two shipping charges.
    I would register with them, load up a "cart" and see how it goes. Try both UAE and Japan. If they're close, I'd maybe go with Japan.
    I did a trial cart, on West Coast Canada, not sure if I got them all; from UAE shipping charge was around $15 CDN.
    Gotta grumble, regarding road salt. That stuff is causing financial carnage. There's gott be some way to scale back on the use of road salt, or find an alternative.
    #2 Mendel Leisk, Oct 9, 2023
  3. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    Figure out a good tool to cut the wires/bars and replace them. It's not worth the hassle trying to get them to work again. Once the hose clamps are removed there's no way the rust/corrosion will interfere with disassembly.
  4. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    Use large diameter panduit straps and the gun to squeeze them tight All you'll ever need If you don't squeeze them too tight and try to kill them you can even pretty easily get them undone and put them back on again although that's the least of your problem generally speaking they'll hold up a lot better than these clamps and then when you want you just cut them loose and have three or four at the ready to reinstall ends the whole shebang. I'm sure in the aftermarket you can also get aluminum alloy clamps from the people that make the cold air intakes You know that all the kids put on the Hondas they should have a whole page full of what look to be billet clamps God knows what they're made of but they're not steel that supposed to rust I don't think.
  5. PriusCamper
    13,465
    5,431
    Lol, I don't even know what that means... But it sounds awesome...
  6. Tombukt2
    13,861
    2,519
    Durham NC
    Panduit straps simply put some people call them zip ties The police use them as instant handcuffs when they don't carry a lot of metal If you get big ones like that are used in the HVAC industry there is wide as those clamps are around those rubber hoses on the intake You use a squeeze tool to install them tightly and they'll be tighter than those clamps which isn't necessary I'm just saying. You can also release them with a scratch all or a little tiny Klein screwdriver and reuse them as needed Panduit is the proper name for zip ties. Maybe it's the company that actually made them or whatever that's what I've always called them. Just like most people don't know what crocus cloth is unless they're over 65. But oh well that's just the role of sandpaper The narrow stuff that plumbers use to clean off the end of the pipe before they sweat the two pieces of copper together.
  7. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
    I ended up finally getting it undone; clamp may or may not be reusable, not sure yet lol but will try ordering from elsewhere than Toyota! Let it soak in pinesol and hot water for a few hours, scrubbed and rinsed down, and repeated that. I’m pretty sure there’s still a lot of stuff Inside but don’t have a brush that gets that far so am reading up on it and seems I can just hose it down (it’s a plastic intake manifold) so fingers crossed.
    Cylinder head just got back from the shop too, so it’s time to start reassembly
    Tombukt2 and PriusCamper like this.
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    . I always called them Ty-Wraps but the US supplier was Panduit.
  9. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  10. rjparker
    11,104
    6,967
    Texas Hill Country
    Ty wraps don't fall apart in the sun. No Walmart or Harbor Freight stuff went to the moon.
    We used Panduit wire ducts ("Panduit") in custom wiring for industrial controls. Allowed efficient troubleshooting and upgrades in one off designs.
  11. Tombukt2
    13,861
    2,519
    Durham NC
    An industry early on when these things first became available I remember the sales people the manufacturer reps and what have you calling these things can do it straps they came very narrow all the way up to I don't know today but back then about 5/16 of an inch wide pretty stout like about the width of some of these clamps were discussing here. Other than that zip ties and I do remember the TY wrap name.
  12. Tombukt2
    13,861
    2,519
    Durham NC
    You've got to be running like a gun cleaning brush up down that long 3/4 inch or so hold that runs all the way down the manifold that the EGR port connects to and then you've got to run brushes down those EGR ports that are centered in each port if you will there's a hole there that you need to clear that goes down to that 3/4 passage that runs all the way down the manifold that needs to be cleared by invasive brushing followed by blasting through with air maybe some decent cleaner but the brush is going to do the trick that's going to open up that passage back like it was which is the goal here.
    Mellyman666 and Mendel Leisk like this.
  13. Mendel Leisk
    42,347
    For the small diameter EGR passages in the intake manifold, Google drinking straw brushes; lots of stores, Canadian Tire, Amazon, have them. I got these:
    Straw Brushes - Lee Valley Tools
    I suspect PineSol is quite basic/caustic? Rinse the stuff out VERY thoroughly, and maybe spritz any of the metal embeds with WD40 or similar, or you’ll have corrosion starting.
    For the intake manifold best to stick with brake cleaner since the embedded metal is not stainless.
    Mellyman666 likes this.
  14. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
    Exactly what I did for the bottle brushes!
    Pinesol I read about online, didn’t know! I rinsed it super well and used brake cleaner instead.
    I just got my head back from the machine shop and let’s just say their service wasn’t amazing. I noticed these 3 small « dents » or « grooves » that I didn’t have before bringing it there. It doesn’t seem to be in the way of making a good deal but wanted to show the experts to get their opinion. I wrote to the shop but seeing their service I doubt I’ll get a reply.
    See notches around edges of the little half circle cut outs. 0133DE47-A0B1-403A-A1E2-5758F97AD2CC.jpeg 5868A5A9-2F04-471F-9DE5-A7117FFBD430.jpeg AD06E5B4-AB5F-4124-861A-852EF9A7A073.jpeg
    TIA
  15. ChapmanF
    19,025
    My first question would be, are you positive you didn't have those before, and they weren't just harder to see because of old gasket leavings or whatever?
    Somebody else may chime in, but if I'm looking at the things you mean, they look too ... regular ... to be dings from the machine shop. Each one is exactly opposite a bored hole visible in its little arc-shaped passage, and my first guess would be they are artifacts from whatever tool at the factory bored those holes.
  16. rjparker
    11,104
    6,967
    Texas Hill Country
    It must be the terrorists
  17. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
    When I looked back at the pics I agree with you I think I had them and they weren’t visible or as noticeable. I’m going to assume if they were there from origin that they won’t interfere with the head gasket change
  18. Mendel Leisk
    42,347
    I’d agree, those chips look original.
    So did they machine the head? It looks like it (to my untrained eye).
  19. Mellyman666
    Mellyman666 Member
    144
    32
    Montréal
    Well I sure hope they did haha they charged me 180$. It is much cleaner than when I brought it in, and they said they performed the tests required! I found myself a friend mechanic who is willing to come and install the timing chain for me (he recommends I get a new timing chain and tensioner, don't know if I should?)
    Tombukt2 and Mendel Leisk like this.
  20. Mendel Leisk
    42,347
    Everything is “probably” fine. I believe there’s chain inspection instruction in the repair manual (full engine section is last link in my signature). Ditto for chain guides and tensioner. Would be good to replace tensioner gasket. Toyota gasket kit includes this gasket I think. Car Care Nut (YouTube Toyota Master Mechanic) says to look guides over for wear, but they tend to be very durable.
