Disconnect fuse prior to brake maintenance?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Nico3d3, Jun 2, 2022.
  1. Nico3d3
    Nico3d3 Junior Member
    37
    16
    Quebec
    Knowing that the brake booster pump have a life of its own, it's probably a good idea to disconnect its fuse before doing any brake maintenance. Sure, you could simply disconnect the battery but, then you lose radio settings. So, which fuse or relay should I disconnect?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Disconnecting the 12V only loses the clock & (I think) calendar settings. Radio presets remain on my '17 Prime and my wife's '17 Prius.
